Ford Escape 3.0 Trouble Code P0354
I have an 05 Escape 3.0, purchased new, never had a problem, serviced regularly, 45k miles. I had purchased a Code Scout 2500 by Autoxray code reader last year for another car I had so I used it on my Escape because the engine light came on and was running poorly. It came up with a P0354 Ingition coil D primary/Secondary circuit error. After reading many of the postings on here I determined it was the front left coil pack, cyl 4. I swapped the front 3 coils several times and watched the error follow the cyl 4 coil to P0355 and P0356. I purchased a coil from NAPA and replaced it and the spark plug. It made the engine run better but the code just won't clear. I have even put one of the other good coils back in cyl 4 but makes no difference. It is now running rough, poping back through the air intake and maintains only the one same code. I unplug the wire to the coil and it makes no difference. I have even disconnected the battery and moved the new plug to a different cyl. Please, any help on this would be appreciated.
PCM is located on the 05 Escape or what else might be upstream from the plug and coil that would have this effect?
You'd probably get more people to read your question if you post your question in the ongoing discussion rather than creating a parallel and duplicate topic.
SUVs and Smart Shopper
Have you figure out what was the problem and what was the repair.I'm having the same problem.
2005 ford escape 3.0l
What resolved to problem?
Did you remove the intake plenum? If you did, you should replace the plenum gaskets.
