Mazda5 Extended Warranty
Am interested in your opinions on extended warranties. We will be buying a 2009 Mazda 5 this spring and am leaning towards not purchasing an extended warranty. Anyone have any experience with either wishing they did purchase the extended warranty, or having purchased it, found they wasted their money? I know it depends on the reliability of the vehicle, and from what I have read it would seem that the Mazda 5 is fairly reliable so that is why I am thinking I will not get the extended warranty. Any opinions or thoughts would be much appreciated. Thanks.
At $1400 it is very tempting especially it is zero dedutible and last 10 years /120k.
What do you guys think? Should I go for it?
Your description sounds like the compressor is NOT the culprit. It sounds like you may have debris (leaves, dirt, branches, and yes even a mouse I have seen this before many many times) inside your blower fan or have a bad blower motor fan assembly. Before you dish out the money for a compressor or a blower motor either DIY or have a shop pull your blower motor/fan assembly out and check that the "squirrel cage" (fan) for lack of a better term is clear of debris or rodent/s. If you park your MZ5 under a tree or around many trees you could have dried up leaves, branches and dirt inside there, and like I said mice do like to crawl in there and can't get out afterward, so be sure to check that there is not a little friend in there rotting away...you'll be sure to start smelling something nasty.
If you have a bad compressor you will most likely either smell a burning rubber type of smell from the drivebelt trying to turn the pulley and or see smoke. If your system is out of refrigerant your compressor will automatically shut down or will not turn on because it cannot pressurize, therefore you may have a leak instead. In all instances, the compressor will not have any impact on the speed of the air coming out of the vents and it will not make your blower motor/fan assembly make noise. Hope this helps.
I'll check it out and keep you posted. Thanks so much for the advice!
And, yeah, since it wasn't a warranty issue, I had to pay for it! $149.95 + tax!
Would a dealership make unnecessary repairs under warranty just to bill Mazda? I know that if they miss-diagnose it, they would not admit to it and just go on.
Is diagnostic not covered? The operation of removing the tank is part of the diagnostic process.
They have to fix the problem and not ask you how to do it. You give them the car with a covered (by the warranty) problem and they give it to you back fixed.
Tell them that you just want the problem fixed under the warranty conditions. If not go to BBB.
It's surprising how many people hire lemon law lawyers or are afraid to talk to BBB. I was in that category until it was just too much. I was surprised how quickly and with no pain the problem was taken care of.
DO IT!
I imported a canada manufactured mazda 5 car into US. It is 2008 model. question is - does the warranty coverage exist the same? is it in km or miles? as car speedometer and odometer are in km.
If the warranty is not covered, are there any recourse?
The engine went in our 2007 Mazda at 108,000 km so it was 8,000 km off warranty. Mazda didn't cover it. Who knows if they would have covered it even with an extended warranty?
