Jeep Grand Cherokee AWD Transfer Case Problems
I was driving in forward then reverse to make a path in the snow when I heard a loud "clunk". My tires spun after that. The Jeep drives fine except that it is all over the place with no traction. Obviously, my 4 wheel drive is out. My Jeep is AWD and you would never even notice anything was wrong except in the inclimate Ohio weather we are having right now. I was told by a friend that my transfer case needs replaced. Now for my 4.7L it is about $2200 for the trasfer case. Could there be something wrong in the case and I would not have to replace the entire thing? Additionally, is it safe to drive in normal road conditions? Can I take it to the dealer and can they tell without taking the whole thing apart?
See Also: All Wheel Drive Explained
I was putting the wheel speed sensor in tonight and noticed the front wheels spun freely in park while breaking the nuts loose. Didn’t think this was normal so I backed into a small ditch forcing the passenger rear wheel to spin. the front wheels were not getting power to pull me out of the small ditch, the passenger rear wheel was the only wheel turning
using a neighbors lift,We lifted it 3 inches off ground, started, and put into gear and the front wheels did not spin
When in park with engine off, both front wheels spin freely when turned by hand
Also with engine off I can turn front driveshaft with hands
Started and lifted off the ground the front driveshaft does turn, but motion stops at the front differential
please help me if there would be any reason for the front drive shaft to be turning under power but the differential not transferring the power to either front wheel. It make no noises when driven at all.
Email me at tsiefert@bellsouth.net with any suggestions
remove filler plug and see if front ring gear is there (could have removed that because of front noise
i run mine in two wheel drive by removing the front axels because they cost so much to replace will find some in pick a part this summer
I love my Jeep but I'm not sure if I love it this much :sick: . If by chance you know or have had any other problems with your Jeep could you message me back, please and ty
I've been told it's the CV Boot, Boot Strap, Transfer Case, etc. How do I identify what the problem really is and what do you think the repair should cost?
Stuck in Truckee...
Has anyone had any of these problems. I really don't believe that about fixing one sensor, and the others going out, but how could I take a chance with my 19 year old?
When you have an engine or transmission problem don't pay for any repairs until you have replaced both your TCM and PCM. These parts can be purchased online, for about $125 each and best of all you can install them yourself.
We have had a huge variety of intermittent error codes and mechanical problems over the years including but not limited to: multiple fuel injector failure, limp mode transmission, engine electrical failure, alternator failure, transmission slipping and/or hard shifting, transmission won't engage, shifter stuck in park, engine won't start, engine quits while driving and the list goes on... The Jeep Dealership said our car was haunted, no kidding!
All of the above issues were fixed when we replaced both the TCM and PCM. It was easy to do ourselves and now we love our 2000 Jeep again. NOTE: The 1997 Jeep was not affected, all of the problems where with the 2000 Jeep as it has a lot more computer controlled components.
Hopefully, this will help you. If it does, let me know and spread the word :-)
(excuse my spelling,on a phone)
I have a '05 Jeep WK and as I was driving aprox. 45mph, my jeep jerked and my RPMs shot up to around 4500-5000 and Immediately lost all speed. I ended up rolling to a stop and had NO power. I tried Drive and selected each gear individually (1-4) as well as reverse. All gears (including reverse) acted as neutral. I first thought it was my transmission, but while on the phone wish the repair company, I told him the same story above. He said to try to push the jeep in park. It rolled! Even park acts as Neutral. He said it was the transfer case. Is this possible? I should also mention that my 4Low doesn't/hasn't worked in a long while. When I attempt to engage that I get a message saying "Service 4WD System" and there has never been an engine error code for that. If you have any quick thoughts or info, please message me at [Email removed]
I have the same problem in my Jeep grand cherokee 1996 zj. There was a whining noise that disappeared after removing the transmission shaft. I do not know whether the problem is in the transfer case or in the differential.
Anybody could assist please.
I had the full wheel drive on and braked hard and swerved to the shoulder to avoid a collision. The Jeep would NOT stop with the brake firmly applied. I started fishtailing and hit the car that cut me off. Then I hit the center divider. The Jeep continued to spin out. I threw the car into park and was able to get it to stop but the wheels continued to spin out. I strongly believe it was the back wheels as the "spin out" sound was behind me. The only thing that was different is that I had the car in Full 4 Wheel Drive. Truly a Ghost in the Machine. The other thing is the key fell out of the ignition and the Jeep was still on. I luckily remembered I had a spare key in the center console. I then was able to shut down the Jeep. I called in insurance, Jeep Dealer, and the Police and nobody seems to care. The Police said the only thing I could do is hire an attorney and start a lawsuit. This thing is going to Kill somebody.
I have been giving it a lot of thought and I have no idea how the transmission could be related to acceleration. I think it has something to do with the fact that I was in Full 4Wheel drive and the transfer case. But, I do not know. Has anybody heard of this? Does anybody know what could be the problem or would cause this?
a note on your key falling out of the ignition switch... there is a recall on this, I believe it covers your 2002, it did on my 2005.
edits came after I double checked my notes.
