Nissan Pathfinder blows cold air while idling
We have found on the internet that many 2005 owners have a problem with the heater blowing cold air while idling. Once we get going again it blows hot air. But we are unable to find a solution. Can anyone help?
I have the same issue with my 2005 Pathfinder LE, even after replacing the radiator last year due to leakage. It also seems to take around 15 minutes for the heat to kick in whie driving, even though the blower seems to kick in with 5 minuts just blowing cold air.
Thank you much!!
2 Is to take the radiator cap off while vehicle front end is jacked up off ground or parked on a slope so while it is heating up the air will be forced out of system.
Hope this helps you out.
We are having the same problem with our 2012 Pathfinder. I thought my husband was exaggerating the lack of heat, it has been in the single digits her for about a week. I used the Pathfinder last night to pick up my daughter at a friends, of course she wasn't ready when I got there so I sat and waited. I am accustomed to the heated seats in my VW so I was really cold. I tried switching to inside air, thinking maybe the heating system simply could not compensate for the very cold outside air. Nothing worked. When she finally came out and we started moving, we had heat. My husband has it at the dealership right now for a scheduled oil change so he will ask them to assess the problem. I am hoping it is something simple like a loose hose or that the system just needs to be bled. We had a problem with air pockets in the heating system of our Porsche. My husband made a tool to bleed even the smallest bubbles from the system. When you use the bleed screw you lose a bit of coolant every time you do it, the way he does it you don't lose coolant.
The suggestion by Epuckett101 worked and fixed my heating problem!! Thanks.
I've been working on cars since I was 16 years old. I've always had a motto "never take your car to the dealer, once you buy it." All they do is run up a $500 bill on you and sometimes you get more problems. This has worked for me. I'm 53 now, and I still do all the work. However, I had a high pitch sound coming from the engine at times when accelerating from a stop. Since I couldn't figure it out I took it to Nissan (I know, I broke my own code). They convinced me it was the intake manifold, the nice mechanic was about my age and certified. He even showed me where the sound would come from. So, I coughed up the $600 dollars to have it replaced. They even tried to bilk me for more money with a "tune up special"another $400 that would include plug change. I declined.
Here's what happened. They had my car 3 days and called to say it was done. I picked up and drove it and about 3 hours after I pick up I hear the same intermittent high pitch sound. I contact the service manager and explain the issue. He agrees to credit me the money next time I bring the car in for service to apply to fix whateer is needed and have a look at the noise. Needless to say, I don't go back to get drained for more money.
The noise comes and goes all summer, but does not indicate any problem driving and sometimes for weeks I don't hear it. Well then winter comes and guess what? My heater is not working at idle. The only time I get heat is when driving and going about 2500 - 3000 rpms. So, as a I said before I do the coolent change, but that doesn't help. I know from previous car work to "burp the cooling system," but as I find out there's a special way to do it on these "vacuum" type cooling systems.
So, I figured out how my heater problem started... The Nissan dealer installed the problem when they replaced the manifold. They did not get the air out of the system once they put it back together and refilled the anti freeze. Of course, I didn't notice in the summer because I don't use heat then. So, I run into a problem they created in the winter first time I go to use the heat.
Thanks Epuckett101, I did exactly as you said and my heating is working now.
I had the same problem few months back, guess before this whole RONA thing.
Anyways I replaced thermostat in my 06 Pathfinder with that of one of the local auto parts store and truck ran ok, however, same symptoms your experiencing.
I know in previous experience, that my pathfinder prefers NISSAN parts at least when it comes to cam sensor.
With that in mind I bought a NISSAN thermostat from dealer and swapped out thermostat again and problem was fixed. I’ll see if I could attach a pic I took of both thermostats.
There was a slight difference. I guess enough to make a change
