2002 Yukon Oil Change Light
I have a 2002 Yukon, and everytime that I do the oil change, the Oil change light comes on after 2000 miles sometimes less. I have to reset it. I do the oil change every 3000 miles and I use synthetic oil.
Is that normal or the gauge is failing?
Depress the gas pedal to the floor three times; do not hold the pedal down; just tap it to the floor 3 times within that 5 seconds. When done, turn the key off. Turn the key on, and the Change Oil will flash like 3 times to let you know it has been reset. You need to do this every time you change the oil.
Are you losing any oil? Do you check the oil life monitor often and watch the "% remaining" go down, or do you just leave that screen hidden until all of a sudden it tells you that it's due for a change?
I was told that the oil counter is just a dust detector, and does not measure the viscosity of the oil. I do not know if that is true or not.
GM oil life monitor
The system cannot tell the difference between regular and synthetic oil. That being the case most use oil sample testing to get a better idea on oil change intervals.
Blackstone Labs
I have an '02 Yukon and I don't have any problems with mine. I get mine changed when the light comes on and reset it then and I'm good to go.
