GMC Yukon Denali Chrome Wheel Problems
chome coming off on 20" ome wheels ona 07 denali
SUVs and Smart Shopper
(a) do nothing and the appearance of the wheels continues to degrade
(b) try to seal the pitting with some chemical sealant to stop or slow down the pitting, or
(c) spend a LOT of money to repair the wheels.
Any news from GM?
2) I don't know if it is a warranty issue. They may call it normal wear and tear if, for example, it's determined to be caused by road salt damage. But I do know that you don't have to return to the dealer where it was purchased to find out. Any GMC dealer can handle a warranty claim, even in another state. Good luck and let us know how it turns out.
William
GM claims it's wear and tear but can't specify what could of caused the wear.
Check out my youtube video with recorded phone calls to General Motors:
http://www.youtube.com/watch?v=v9Ta4wiGuy8
And a GM Bulletin regarding the peeling chrome wheels issue:
#07-03-10-015: General Motors New Vehicle Wheel Warranty Coverage - (Nov 6, 2007)
Subject:General Motors New Vehicle Wheel Warranty Coverage
Models:1996-2008 GM Passenger Cars and Light Duty Trucks (including Saturn)
2003-2008 HUMMER H2
2006-2008 HUMMER H3
2005-2008 Saab 9-7X
http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2037107&from=sm#ss1-2037107
The General Motors New Vehicle Wheel Warranty
This bulletin has been issued to clarify warrantable conditions on GM OEM wheels. It is our intent that this one document will answer many of the warranty scenarios you are likely to encounter. Unlike other parts of the vehicle, wheels encounter various road hazards, corrosive substances and abuses that may present questions in both the mind of the customer and the dealer. Eligible conditions are warranted for the full term of the New Vehicle Warranty. Currently for Chevrolet (except Corvette), Pontiac and Saturn, this is 3 years / 36,000 miles (60,000 km) and for Buick, Cadillac, HUMMER and Corvette, coverage is for 4 years / 50,000 miles (80,000 km).
http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2037107&from=sm#ss2-2037107
Information Sources for Wheel Issues
The following GM Service Bulletins contain information useful to minimizing possible damage, and reducing customer concerns that may arise through incorrect servicing and improper cleaning products.
• #00-03-10-002D - Chemical Staining, Pitting, Corrosion and/or Spotted Appearance of Chromed Aluminum Wheels
• #04-03-10-012A - Pitting and Brake Dust on Chrome Wheels
• #06-03-10-004 - Proper Use of OEM Service Wheel Weights, Marring and/or Damage Due to Use of Non-OEM and/or Incorrect Wheel Weight Installation
• #06-03-10-010 - Information on Proper Wheel Changing Procedures and Cautions
http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2037107&from=sm#ss3-2037107
What is NOT Warrantable
GM provides many different styles and finishes for our passenger car and truck wheels. You will find both steel and aluminum wheels with painted, polished or chrome finishes available. While each of these types must meet GM durability standards for road impacts and finish appearance, there are conditions that are not warrantable.
Curb Impact / Scrapes
Wheels that have been damaged through abuse are not warrantable. Finish scraping and wheel flanges that have been damaged due to curb impact are not warrantable.
Bent Wheel Flanges / Cracked Wheels
Bent wheels and cracked wheels due to road hazards are not warrantable. In many cases bent and cracked wheels result from driving on low tire air pressure or a flat tire. Low tire pressures dramatically reduce the impact protection the wheel has and lowers the threshold where damage may occur.
Finish Damage / Streaking / Pitting / Corrosion
There are many different types of finish damage possible, resulting from aggressive cleaning products, road chemicals, poor tire changing practices, or manufacturing processes. Some of these are warrantable while others indicate abuse. See the Finish Damage sections below, which give examples of the different types of specific finish concern issues you may encounter.
Warrantable Issues
Any defects in the finish, balance, or structure of the wheel resulting from improper manufacture are covered under the New Vehicle Warranty for the full time and mileage limits of that warranty. Typical covered finish issues that you may encounter are:
• Flaky or pitted chrome on the visible wheel surface indicating poor adhesion of the plating.
• Polished or machined aluminum wheels that exhibit Filiform Corrosion (chalky white lines under the clear coating) This condition is warrantable, unless it is caused by incorrect wheel weight application and use.
• Wheel center caps that exhibit similar conditions to warrantable wheel concerns.
• Thin or poor paint finish quality on painted wheels. Bubbling / Flaking of the paint.
• Paint damage incurred during stick-on wheel weight changes. (See Stick-On Wheel Weight Paint Damage or Paint Flaking/Peeling Backside of Wheel)
• Flaking or peeling on backside surface of wheel indicating poor adhesion of the plating (See Stick-On Wheel Weight Paint Damage or Paint Flaking/Peeling Backside of Wheel).
I took my 2007 Denali into a local dealer here in Vancouver BC and the Service Manager approved all four wheels to be replaced, no questions asked.
I showed him the GM Service Bulletin on chrome wheels and he agreed.
All four were ordered and installed in a week.
I actually bought the truck in Phoenix AZ.
After two weeks of run around, I eventually ended up getting an appointment to see the zone man ( int this case a woman ) who handled the first dealership I had visited. She was kind and understanding, and within an hour of meeting her, she called me back and told me they would indeed replace all four wheels at no charge. The wheels I now have on the vehicle are all brand new, and have no problems. They are 22" wheels.
I wanted to let everyone know that you can indeed get free wheel replacements, you simply cannot take no for an answer, and you must elivate it up to the zone manager or district manager level.
Hope this helps!
PS
The source of hte damage to the wheels was most likely road chemicals-specifically and as mentioned int he service bulletin, calcium chloride....there aer pictures in the service bulletin that illustrate the problem.
