The sales person who sold me the vehicle stated that all the 2007 Sienna's make the same noise. A mechanic I know; who owns a 2006 Sienna, stated that it sounds like one of the "lifters is sticking." If I accelerate too quickly, the vehicle almost sounds like a diesel (until I get over 2K RPMs). Not sure if this issue has been addressed in the past (on this board), any feedback is appreciated.
It is a chain-driven camshaft so there may be more noise than the old belt-driven cams on the 3.3l, but definitely no knocking.
My trans hesitates a little bit, our 2009 Forester's 4EAT is much more responsive.
Even my Lexus dealer service did not know that the front diff'l case must be drained separately and has its own drain plug, that's why 5 quarts are required.
I went through the above procedure, as the ATF was burned and dirty, at only 40,000 miles and am now at close to 80,000 miles and am keeping a close eye on the ATF condition.
I have question regarding Toyota sienna 2010 Transmission.
i Know That 4-D = drive
what about 3 and 2-L any idea
So, say you put it in 3 - it will not use 4th and 5th gear. Say you are towing and climbing a steep hill, so you don't want it to shift to 4th and lug the engine.
4 is actually not Drive, because it locks out overdrive (5th on 09 and prior and 5+6th on the new ones).
that its mean if put in 3. i will be using gear 1,2 and 3 or 3 only
and if put in 2L. i will be using gear 1 and 2 or 2 only
i will put in 3 or 2L when the car in total stop.
or like its kind of shifting gears from 4-D to 3 or 2L when i am driving .?????
It's better than the U660E that replaced it. That got complaints about hesitation, especially the year it came out.
Sorry to hear it.
I take it no extended warranty? Not in the 5/60 powertrain standard coverage?
I have had the van since new. I know when there is something not working right. The van slows down quicker than it used to and makes a faint grinding/rubbing sound when I remove my foot from the accelerator until it hits about 20mph and then it seems to stop making the noise and coast normally.
I used to take my foot off of the accelerator when coasting down a hill as I would always end up picking up speed. Now the van slows down when going down a hill as if I'm pulling an anchor.
Today when I got home and put it in park the van started to roll down my driveway.
Nothing wrong with Toyota????
Buyer beware!
Link to the TSB on my cloud site:
http://www.mediafire.com/view/?9s6zw96tncvtbh4
Recommended service is the "4 quarts at a time method".
There are actually two vehicle speed sensors mounted ON your transmission (not INSIDE), so they are relatively easy to test and replace if necessary. They serve several functions including comparison to the wheel speed sensors for stability control operation, they drive the speedometer, and they are used with the transmission control unit to help regulate transmission shifts including valve body pressures to ensure smooth operation. Perhaps your poor shift quality was related to a speed sensor problem all along. I certainly wouldn't jump to replacing the transmission until you know if this is a real mechanical problem or just electronics.
Is your speedometer working correctly? A dead speedometer is one outcome of a failed sensor(s). If your 2004 has stability control do you have an ABS or TRAC light? How is the transmission working now? Did the flush & fill help? Did something feel different when the code popped up? If everything seems OK, then your sensors probably just had a momentary glitch and are probably fine. Not knowing exactly how they work, I cannot tell you if a dirty system is at play here or not, or if the flush would help or hurt.
If everything is OK, I'd just reset the code and see if it returns.
