Suburban Windshield Wipers Will Not Turn Off
can't turn off, had to remove fuse, it will change speed from slow to fast. will not work in the "inter-mitten" mode, just slow or fast........any help???
But, as you have one like I do we need to live with it as long as we have these pieces of junk, right?
So, about the windshield wipers. I recently installed a rain detecting automatic wiper control in my '04 Tahoe and I learned something about the Tahoe / Suburban wiper control. The switch that you use for switching wipers on and off and to different intermittent settings actually changes signals to the wiper control module. The speed of the wipers is actually controlled by changing resistance between two wires when you turn the control switch. To me this means that it is very unlikely that there is a switch problem causing the wipers to not turn off. Now, this does not mean that it cannot be the reason but I would look at a problem with the wiper control module instead, i.e. possibly replacing it.
Arrie
I'm trouble shooting it now. Did you find out what it was. I heard maybe the motor
could be gone on mine.
I did have a problem with my '97 wiper, and it was a cracked circuit board in the wiper motor. Relatively simple replacement, bought a motor unit at Pep Boys, took the old one out and put the new one in, and good to go.
WIthout any manuals, I'd say check your fuses to make sure you don't have a blown wiper fuse, then check for voltage on the plug to the wiper motor. If you have voltage there yet the motor isn't working, then I'd be calling a parts store to find out what a wiper motor costs.
It is located under the air vents by the wipers.
Arrie
