Time to replace shocks/struts on '00 Trooper - recommendations?
Since it's not possible to search discussions within this forum by a keyword in the title, I am starting a new one....
Our '00 Trooper has ~120k miles on it. It's used as an everyday vehicle -- no off roading or heavy hauling but we like its utility, size and reliability. The ride has gotten a little bouncy lately, and it has always had that feeling like it's going to tip in corners. It seems like it might be time to replace the shocks/struts. Any suggestions for specific brands/types?
Don't mind spending a little more to improve confidence in cornering without sacrificing too much on ride comfort. A lower ride height wouldn't be a bad thing aesthetically either, but not a requirement. Again, we don't use our Trooper for any off-roading so clearance isn't an issue.
In fact, the default setting for searches is the title. An additional setting will search message bodies.
SUVs and Smart Shopper
Good luck.......
I'm going to replace the sway bushings today, for better cornering. I bought 4 Energy Suspension greasable poly bushings. I may need to search the forum for help here -- I got 1 1/8" for the front, which is the right size, but it doesn't seem like the brackets will fit (and I think I got the smaller of the two bracket sizes), so I'm a little confused.
