Freestyle keypad code
                    We purchased an '06 Freestyle Limited, but did not have the keypad code.  Were told we could go to a dealership and, for a fee, have it retrieved from the vehicle computer.  Also that the code could be found on the computer module.  Where is the module, and is the code easy to find on it?  We opened the access door under the steering wheel thinking it might be there, but not sure.  Could not find any information in the owners manual...
SUVs and Smart Shopper
Hopefully this is not too obvious, but I kept the card listing the code with my owners manual, in the folder supplied with the car. Did you get the folder and OM?
This is from the OM:
"KEYLESS ENTRY SYSTEM
You can use the keyless entry
keypad to:
• lock or unlock the doors without using a key.
• activate or deactivate the autolock feature.
The keypad can be operated with the factory set 5–digit entry code; this code is located on the owner’s wallet card in the glove box, is marked on the computer module, and is available from your authorized dealer. You can also
create your own 5–digit personal entry code.
When pressing the controls on the keypad, press the middle of the
controls to ensure a good activation."
If you didn't get the OM, there is a forum on Edmunds for online owners' manuals.
