2009 GRAND CARAVAN/T&C FEED BACK
Just bought two of these (a Grand for me and T&C for my daughter). We both got the 4.0 with 6 speed and they drive perfect. I was a mechanic until 911 and these seem to be tight well built vehicles. Just wondered how eveyone else was doing with their 2009 GC and TC.
My only regret is that I did not get a back up warning system.
PS// the Town and Country has different options so check it out before before you buy.
Whatever you want make sure the vehicle has it. Doing this stuff afterwards is not practical.
A few other items of note:
1) The 3.8 has a long-long history of reliability with many engines reaching into the three and four hundred thousand mile range.
2) The two 3.8s in our two minivans (a 1998 and a 2003) have amassed a combined 290,000 miles without even a single engine related repair. Not so much as even a small oil leak from the valve covers.
3) The 3.8 design, while a bit "dated", uses a timing chain to actuate the cam and valve train. This timing chain arrangement is in most cases, good to go for the life of the vehicle.
4) The new 4.0 engine is as of yet an unproven engine from a reliability stand point (although I have little doubt that it will ultimately be regarded as a very good engine).
5) The new 4.0 engine uses a timing belt to actuate the overhead cams, and the belt needs to be replace on a periodic basis (not all that often, but I'm betting it isn't all that cheap when replacement time comes).
Were it that we were in the market for yet another minivan, we would think long and hard over whether to opt for the tried-and-true 3.8, or go with the more powerful 4.0.
Best regards,
Shipo
(SXTL)The 4.0 with leather has the sport suspension and 17' wheels in the Dodge. My daughters does not have that option in a more loaded Town and Country with a 4.0/6 speed. I highly suggest you cherry pick one with a sport suspension off the lot. It sounds like the 3.8 and 4.0 will be fine by the feed back I have seen so far. But again, be sure to drive it and decide for your self with your wife in the back seat. I drove 8 units before I bought the 4.0/6 speed with leather. I was just plain quiet and shifted all 6 times like a clock.
BTW// all the vans drove fine for me, we just like a quiet vehicle. If you need a cheap van the 3.3 base units drove fine. They just had more cabin noise.
Also the 3.8 looked easier for a mechanic to work on/maybe!
We have 7 units in our family and have sold 5 over the years. Not a single one had a bad engine and three had transmission problems (two of those had a 100K plus). Nothing since 2001 has had any problems to speak of. I consider the Dodge vans one of the highest quality products on the road.
Important note for me. I do not or any member of my family work for Dodge or have ever worked for Dodge in any capacity. I am just a consumer who has ejoyed this product as well as my Chevy trucks and Honda Civics. .
Good points, but my Mitsubishi 3.0 1994 Dodge Caravan with a timing belt was the most solid engine I have ever owned. I replaced the belt myself at the shop at 70K as well as the water pump, oil seals and all tensioner pulleys. Quality engine in every way. Do not let the timing belt run you off even though I prefer a chain myself. Most newer designed engines except the Honda Hybrid have timing belts.
I was wondering if the 4.0L engine would make any difference or should I just save extra money and stick with the 3.8L (if the overall handling is the same between the 3.8 and the 4.0).
The 3.3 was a little slow and a little noisy in the cabin, but ok.
PS/ My daughter basically bought the vehicle you are describing. She wanted the DVD system and leather. However the TC did not have 17" wheels or sport suspension. But she loves it and was driving a Honda Civic hybrid until she out grew it.
102,000 Miles (170,000 km) or
102 Months Maintenance
Service Schedule
❏ Change the engine oil and engine oil
filter.
❏ Rotate tires.
❏ Flush and replace the engine coolant.
❏ Replace the ignition cables (3.3L and
3.8L engines).
❏ Replace the spark plugs (3.3L, 3.8L,
and 4.0L engines).
❏ Replace the timing belt (4.0L engine).
BTW// I noticed most of the vehicles on the lot had a 3.8 engine. So in answer to all those questions the 3.8 and 4.0 should be perfect. The manager really liked the 4.0 and 6 speed combo and it is the first year for this engine and is a design effort with another large company. He could not remember which one.
So if you don't trust your own judgment on this one item, then get the 3.8. With a full lifetime warranty and the Democrats not willing to let any of the big 3 go completely out of business, I think you are safe. Remember in chapter 11 your warranties are still good.
Road trip to Disney world went fine. 26.7 MPG at 70MPH.
24.9 at 80 MPH. I think this beast would get great MPG at 50MPH. 19 MPG to work and back.
It used a little oil the first 1000 miles but seems to have stopped once the rings set. This engine and tranny rock folks. I found out that Mercedes Benz designed the drive train and this is the first year it made production.
Also had a talk with the dealer and was told all their engine options have timing chains designed to last the life of the engine without maintenance or adjustment. He made a big point of telling me that. There was a post here that was talking about the 4.0 liter having a timing belt? Just wondering about that reference or clarification.
The 4.0 and 6 speed are a good combo but this is a brand new engine designed by Mercedes Benz. It runs like it is a balanced engine. My daughter has the same vehicle and loves it. The 3.8 has been around a long time and has a proven track record. But with the lifetime warranty who cares. Government backed too.
As for the new 62TE 6-Speed automatic, it also traces its roots back to earlier Chrysler automatic transmissions (from the 4-Speed units of the 1990s and 2000s in this case). Yes, its supposed to be greatly upgraded, stronger, more reliable, and offer much improved performance and fuel economy, but no, it was NOT designed by Mercedes-Benz (and given the automatic transmission issues they've had starting in the mid to late 1990s, I'm not sure you'd want it to be).
Best regards,
Shipo
http://www.allpar.com/mopar/38-40.html
It is somewhat comforting to know there is a history of longevity and proven performance behind the 4.0 derived from the 3.5. Given the information about the improvements in the design and its performance data to date I think I will go for the 4.0. Its only $630. for the upgrade in the SXT. that's about the same as the towing prep package and with that you don't even get the trailer hitch out of them. I'm sure the difference will be well worth it especially once I'm towing something and the MPG info looks very promising so far.
Regards, Dave
Just to be clear about this; the 4.0 liter engine has a Timing Belt, not a Timing Chain.
An excerpt from a Town & Country Owner's Manual:
Page 494
Chapter 8 - Maintenance Schedules
Replace the timing belt on 4.0L engines. -- 102,000 miles -- 170,000 KM -- 102 months
I hope this helps.
Best regards,
Shipo
Dave
PS/ I ordered all the service manuals so that should settle the matter when they get here unless someone has built this engine on this thread. If so please speak up.
PS/2 On fit and finish I consider the paint job and interior perfect and better than my Honda. As far as body parts fit they are not as good as a Toyota or Honda but good enough for me and I am picky. Also with all the sliding doors I bet it is a night mare to align up everything perfect.
As for reference points, the AllPar web site is always a fount of information regarding all things Chrysler. In this case, please check out the following two links:
http://www.allpar.com/mopar/transmissions/62TE.html
Best regards,
Shipo
Thanks shipo
PS/ I hope Fiat and Dodge make a deal thats good for all of us.
PS2// I noticed some minor mileage errors in one of my posts. All I can say is that the 17/25 is a conservative number. I am running 40 PSI and will be putting in synthetic oil the next earl change. lol
Thanks again for your input.
Dave
http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=430&Keyword=timing+b- elt&KeywordCat=Belt+-+Camshaft%2fTiming&VehCode=Y
Best regards,
Shipo
Dave
I had a reply from Dodge today about my question regarding the 4.0L timing chain or timing belt. (I'm sure it is a timing belt) They basically said ask your dealer. I was a bit put off by the reply but perhaps the person answering emails doesn't pay attention to whats in them or what I was asking. there all so busy trying to dodge (no pun intended) bankruptcy and partner with Fiat they probably don't have time for pesky emails from customers.
Dave
So sorry guys/ 2009 only.
Best regards,
Shipo
While we would have not thought of looking at GC and TC (were set on Sienna and Odyssey), you cannot ignore the deals being offered, so we did this past weekend.
We looked at both 2009 GC and TC 25th anniversary editions and both were really nice.
Can someone elaborate on which one is better? I could not see any difference in the leather interior or the options but GC seemed to have the 4.0 Lit engine by default as well as the price about 2K less than TC.
I am scratching my head over why the TC is more expensive. Any help you can offer would be appreciated.
My wife and I just bought a 2009 TC touring with the 4.0 engine last week. Took it to Pennsylvania Dutch country for a little 2 day getaway with the kids and am really enjoying the satellite radio for us and the TV/DVD for the kids. The trip was a little over 200 miles and we averaged only about 23 mpg, mostly at highway speeds of 60-70mph. That was with 2 adults, 3 small kids and all our luggage. There were a few times when we did some city driving and had the car parked and ran the engine longer than we should have, so those things could have affected the mpg. I'm not worried about it, we'll see how it does for the next road trip soon enough.
Kevin
Everyone, the 4 wheel disk breaks are awesome, so check the rotors with your fingers on the front every 3000 miles for roughness and report back. thanks all!
Dave
PS/ My stable is Honda 2007 Hybrid Civic and a Prius 2009 touring package 6. Dodge pulls all that weight with speed and economy that is amazing to say the least.
"make an offer and walk away if you are not satisfied. They will call back. Trust me."
I'm going to have that framed for my office.
Dave
PS// I still don't have my service CDs. Even though you can order them online they are not available. ARGH!
We are very happy with this van and althow it may not have the luxury car drivers seat apeal of the Honda it also dose not have the recall history of the Oddisy platforam. It is a more servicabul van with the stow and go, better fuel economy, larger engine, increased towing capacity and better warenty. It is just as qwiet as the Honda inside and out and we feel lookes better. we also paid 2 grand less than the best price we could get on the Honda.
All in all this is the best time to buy the Dodge Grand Caravan. (Chrysler wows not with standing) We have every confidence in this car. If your looking to buy go for the SXT with the 4.0L you will not regret it. Considering all you can get with the SXT package and the price you can get it for there is little incentive to go with the base models.
Dave
Yep! Me and my daughter are happy so far with our vans. Mine seems to not use oil anymore and I am running full synthetic. The dealer adjusted the toe and drivers door to my satisfaction.
Good luck Dave getting your wife to let go of it. LOL
I have yet to drive it to work.
It was an agonizing decision to chose between the Honda and the Dodge, the bankruptcy issue had to be considered, and the Honda Odyssey is no slouch in the minivan market. But after the 3rd day I went back to Dodge and sat in the back seat of a van with my 3 and 1 year old boys, looked around a bit and could feel it was the right thing to do. The Honda just didn't have the design features that were important to us, it would cost us more and with its meager warranty and less than ironclad track record wasn't going to do it for us.
The thing to consider about Chrysler is that if there design team and the people on the factory floor can forward a winning van like this while being cramped and downsized at every turn by the poorest of corporate management (Cerberus) Imagine what they could accomplished with the proper support. They deserve to have that chance. I'm crossing my fingers Dodge will have that opportunity and be around for a long time to come.
Dave
Hope mine lasts for 200K and never needs warranty work.
Dave
Dave
From the Baltimore News2 website
Automakers and the government will set up an account and contribute funds totaling 125 percent of the expected cost of servicing warranty claims. The automakers will put in 15 percent of the anticipated cost and the Treasury Department will put up 110 percent as a loan.
If an automaker failed, the program would appoint an administrator who will "identify an auto service provider to supply warranty services." The fund would pay for covered repairs.
It's not clear whether consumers would have a choice of repair shops. "It might be something like a health care plan where you have to go to an in-network provider," says Jeff Schuster, executive director of forecasting with J.D. Power and Associates.
Looks as though some here have had good luck with the 2009 line-up; this gives me some confidence about giving the T&C some more thought.....The offers/deals right now are also a big bonus, and a good reason to buy a T&C; hopefully they'll continue to have good rebates/financing this May when I'm ready to buy.
Best of luck to you.
Dave
