92 GMC Conversion Van please help
                    There is something causing the battery to drain.  After 48 hours the battery will be dead but it can be recharged enough to drive.  If I unhook the battery it seems to solve the issue because it will still have juice left to restart the vehicle.
Yesterday, while I was driving, the van just shut off. I noticed that the power antenna was on the fritz and kept going up and down.
Does anyone have any idea what this problem could be?
I also have the drain issue. Some other sites pointed to problem with GMC and the stock radio drawing more power. I dont have a radio installed but pulled my horn,cig lighter and accessories fuse which seems to slow the problem. In the end though I like you have been disconnecting the battery.
Im going to have it looked at in the coming weeks and will reply with the found issue if any.
