Visitor Agreement.
I've had many a roof rack, but not once have I had a heavy load up there. I use 'em occassionaly for a canoe (58 lbs) a 12' ladder, fence stakes etc. A perfectly usefull accessory, when you need one.
Larry
Kheitnz1: What you articulated is a theory only. Maybe you have convinced yourself. But you don't know whether your "airfoil" theory actually has any noticeable effect. If the spoiler forces more air over the window, then it also forces more rain and dirt over the window. You would have to drive 4Runners with and without spoilers under identical conditions to test your theory. I'd bet the aerodynamics of a 4Runner without a spoiler are so strong that any change made by the spoiler is negligible and inconsequential.
Grubbs1: You make a good point about the shade provided by a spoiler.
ASK TOYOTA
The spoiler is shaped to redirect airflow down over the tailgate and it works. They do this because the rear window rolls down and the idea of keeping the area clean is a GOOD one. All you have to do is feel the inside of the spoiler to see it is shaped that way!
They have done this on 4Runners for MANY YEARS. Like I said, it is one of the few functional spoilers out there that does it's job.
V8 vs. V6? I know the V6 has more HP, but how does that translate to every day driving? Does the added torque of the V8 make it worth the loss in gas mileage?
Color Keyed 04's vs. Black trim 03's? I haven't seen many Color Keyed Sports around town yet. Does this give it a more sporty look (I'm considering black & galactic grey).
Thanks for your input.
Only you can decide that (if it is more sporty). IMO, if you'll be driving thru dry brush and scraping up the fenders anf front end, look for a '03 clad truck. Appearance-wise, the color-keyed looks better to me (and must sell better, or why the change?).
Black is a nice color choice, and looks great on this truck. Good luck.
Larry
Pursuant to my posts above, I went with the V8 over the 6 simply for the way the truck felt. They do drive differently. This is due not only because of the engine size but also due to the 5 speed automatic transmission in the V8's. The V6's have a four speed tranny, as far as I know. You simply need to drive each one and make your own decision. You also need to consider whether more torque is more important in the V8.
I personally did not like the cladding. It is a dark grey, by the way, not black. There is a difference. I was able to compare with and without the cladding side-by-side. This made my decision much easier. Good luck!
Mac0822, as far as the V8 goes, I love mine. There is a significant torque advantage, but it's only an advantage if you use it. The V8 is a hair quicker to 60, but nothing to truly rave about over our V6 brethren. There is only a 1mpg penalty in the V8. You can buy either one confidently, but you should test drive both and see for yourself and consider what your needs are. If you do alot of heavier towing that may include significant updrades, you might want to do yourself a favor and get a V8.
http://pressroom.toyota.com/
I have asked three different dealers about the air suspension's advantage for towing a 4000 lb. trailer. They each had no idea if it would work, this write-up from (pressroom.toyota.com) explains in some detail.
......."A rear air suspension with X-REAS Sport Enhancement Suspension is available on Limited models with a V8 engine for improved ride and performance when towing or hauling heavy loads. The air suspension uses linear height sensors to automatically adjust the ride height in accordance with the vehicle load".
http://pressroom.toyota.com/photo_library/display_release.html?id- - =20044runner_r
For spec's, click on: 2004 4Runner Specifications:
http://pressroom.toyota.com/photo_library/display.html?kw=4Runner
Thanks for the input.
Okay. I'm convinced.
Aaron
My dealer did that to an unsold blu w/grey cladding 4Runner. The grey factory grey wheelwell cladding has the bold raised ridge design every few inches, wheras the factory painted wheelwell cladding is a smoother, ridgeless design. That's the tipoff if the grey cladding has been painted. As of Saturday it still hadn't sold; it was painted 3 months ago.
Larry
With this in mind, in my last posting I was merely trying to be complete in my positive comments about the new 4Runner's "spoiler" by saying that it surely doesn't do a darn thing for traction, and that its main advantage is to create favorable wind flow over the rear window. Most of us know this intuitively, but there may be a few who erroniously believe that a rear "spoiler" on a typical road vehicle might somehow afford the same intended aerodynamic benefits as seen with high-speeds race vehicles. While the 4Runner's "spoiler" surely creates enough downward-directed wind force to help keep the rear glass "cleaner", I doubt it creates enough "lift" to matter at all (unless you plan to somehow fly the vehicle), nor do I think it creates enough drag to improve downward traction forces.
After changing the oil how do you reset the system and can it be set for 7500 miles instead of 5000 miles?
1. what grade gasoline is best? i just filled the tank for the first time with middle grade
2. am i always in 4-wheel drive? hard to understand from the manual.
3. for some reason it seems my 10 speaker system is only coming through the front center...cant seem to get all inclusive sound. i have not played yet with the rear speak remote...should something be turned on back there??? seems odd.
any help much appreciated!!!!!
If your V8 is a 4WD model, then it is always in 4WD. Only the V6 model is part-time. Regular unleaded is just fine. You'd just be burning xtra money with the super-unleaded.
lpm141 :
Outside circulation is fine for regular use, but use the inside re-circulation for air conditioning. It will keep the cabin cooler more efficiently and will blow the air in a little harder.
1. I have been using regular grade gasoline (87) and have had no problems up to now (3200 miles).
2. You are always in 4wd. The torque is basically divided 60% Rear/40% Front unter typical conditions. When there is front wheel slippage, the computer will send increased torque to the front wheels.
3. As for your stereo, you might need to make sure that the fader controls are centered. Otherwise, you may have a genuine problem and need to take your vehicle back to the dealer. The rear audio system does not affect the main system.
Hope you enjoy your new suv
Practically all manufacturers provide some type of roadside assistance in one form or another. Don't despair, AAA is always available at a moderate cost and some manufacturers actually contract their services as part of their roadside assistance program.
Personally, I have AAA Plus and the Toyota Roadside Assistance plan. It does give peace of mind.
lpm141 :
You can try compensating by "fading" the sound toward the rear of the vehicle, but this isn't a great fix because the speakers in the back seat area are underpowered and sound muffled. Try sticking your head down next to one of them while they're playing, and you'll see what I mean.
I hated the 'mono' JBL system so much that I disconnected the front center speaker in my 4Runner. I had to tweak the balance and tone a little afterwards, but it sounds now like a fairly good system. Not great, but good. I think that's the best you can hope for.
I don't recall the price of the JBL, but I doubt you can get a better aftermarket system for the price when you consider a head unit and 10 speakers. If I was going to do it all over again I would take the standard Toyota system and upgrade the speakers.
I brought my own CD to the dealer to test them both. After fiddling a bit, I got the 10 speaker version to sound pretty good. Then I played with the basic stereo. Not bad either. The truck I got off the lot was equipped with just the basic stereo (6 speakers, single CD, cassette, etc.) After just a few days, I'm glad I got the basic. The truck is so quiet that the stereo sounds great at normal listening levels. FM reception is very good, controls are easy to use. Real good unit for a factory basic. Maybe one day I'll upgrade some of the speakers, but not yet.
Larry
P.S. I've had GREAT car sound systems in the past. I would usually crank it up for my sons for a few seconds (bragging rights), then turn it down for the remainder of the car's life. Now I'd rather have the cash (instead of the better stereo) for road trip money. $700.00 will buy a lot of gasoline.
Larry
I traded in a Honda Odyssey EX with a 6 speaker system on my 4Runner. Compared to the Toyota system, the Honda system was really a POS.
I really like the JBL. I've gotten comments from friends sitting in the back seat about how good it sounds. I think I have the bass on 5, midrange on 0 or 1, and the treble at 3 or 4. Whether surround on or off sounds better depends on what I'm listening to, I think. I don't think I have it faded at all.
I also have some Klaus Shultz electronic semi-classical CD's. They test the response of any system.
Over the past three weeks I have called six local dealers in the South Jersey area to locate an 04 4.7L with SR, GY, RF, RL, CF, NF, and NV. One dealer said probably the end of November, others say to call every two weeks to check their allotment lists. Maybe this has something to do with a demand for the navigation system with the back-up camera? I did a quick Internet search of mega dealers like Longo in CA. and Hudson in NJ. They also have no 04 Limited's completely spec'd on their inventory lists. With these options this vehicle is probably a small percentage of 4Runners sold. Or maybe this is just a regional shortage?
After reading the posts and test driving an 03 with the navigation I am sold on this feature.
Anyone out there have an 04 with the navigation system?
"air-recirculate" feature when needed, I don't think it's a good idea to chronically leave the system in air-recirculate mode, because: 1) This somewhat deprives the cabin of a constant source of incoming FRESH air, which may eventually cause the cabin to smell stale; 2) At startups during hot, humid weather, the cool air-conditioned air that flows through the duct work will tend to cause moisture formation when it hits the hot, humid air it displaces in the ducts. (In addition, any occupants are of course constantly exhaling very humidified air with each breath, and this adds much to the air moisture burden inside the cabin.) Now, if this moisture is allowed to accumulate in the air ducts and vents, it will tend to encourage the growth/overgrowth of very foul smelling MILDEW. Once this mildew forms, it multiplies, and can be very difficult if not impossible to fully remove, and the stench may never be eliminated. To help avoid mildew, stale cabin odor, etc., it is therefore very important to keep the airflow selector switch at the "fresh" air setting whenever recirculated air is not necessary, since this keeps the ducts, vents, and the cabin constantly flushed and replenished with clean outside air, which in turn helps to prevent moisture and mildew from forming in the ducts and vents. If you smoke in the vehicle, this is another reason to keep fresh air circulating whenever possible. Finally, when "air-recirculate" is selected along with higher fan speed settings, this causes an increase in the parasitic load on the electrical system, leading to increased fuel consumption.
For the same reason I will purchase the 7 year / 100,000 Platinum for my new 4Runner (if it ever arrives). With the navigation, air suspension, computer chips and power just about everything, this may be a $1000.00 well spent.
I will be using the air suspension for towing so if I need to replace this system, the extended bumper to bumper warranty will be more than just piece of mind.
any of you 03/04 sport edition owners out there not like or wish they didn't have the hood scoop?
just curious on you're thoughts, and if there is anyone out there that knows any way i can get a hood (w/ scoop) titanium silver, and replace my stock hood with it.....
driving larger cars or SUVs, despite whether you traded from big to small or if you still have the larger vehicle. He's especially looking for drivers of the Mini Cooper, Honda Civic, Ford Focus, Dodge Neon, Hyundai Tiburon and Mazda Protege. Please respond to jfallon@edmunds.com by Tuesday, October 28, 2003 with your daytime contact info and the type of vehicles you had and have.
MODERATOR /ADMINISTRATOR
Review your vehicle
Not really a luxury car so gives it some sporty look
Maybe there is a problem with the catalytic converter. It could just be a defect of some sort.
