Bought a 2005 Dodge Grand Caravan with 98,180 miles on it
in Chrysler
Bought a 2005 Dodge Grand Caravan with 98,180 miles on it. Had it inspected by my mechanic and he told me it was good to go. Took the family on a long road trip and put about 2,000 miles on it. About 8 hours away from home the engine light appears and I take it to an Autozone and get the code checked out. Its and EGR code, no big problem according to the attendent.
I take a look under the van and notice transmission fluid leaking. I decide to stay in town since I have family there and have it looked at in the morning. The transmission shop owner told me it was could be the hoses, common problem. He called ma back and told me that the pan gasket needed to be replaced. So he replaced the pan gasket, new screws and the leak stops. Cost $148 and the engine light is gone. Big relief, or so I thought.
Back on the road
About 1 hour from the house the engine light comes back on, I'm thinking it has to be low on gas since it is almost empty. Wrong. filled the tank and the engine light is still on. what to do? I see no other visual problems, van runs great., transmission does not slip. no more leaks. What else to do?
Back on the road
No problems, Van is running great. I hope it was just a false alarm since I was close to running on empty when the CEL appeared.
! added over 2,100 miles on this recent road trip and am very impressed.
Current mileage: 100,350.
The van is now owned by a good friend, has about 150,000 on it and the light still comes on whenever it feels like it. Never had any other problem with it other than a new ignition switch at 110,000.
It's a great van and the whole family loves it.
Disconnect the battery and see if that will work. Other than that your going to have to replace the egr valve. Don't know how much it wil cost, but I was told that they had to remove the exhaust manifold to get to the EGR valve.
I have a ~$50 Accutron that does those two things, and it's worked fine for my uses.
I got 174,000 miles on our '94 Caravan. Except for a transmission rebuild (which thankfully happened when it was still under warranty, which was 70,000 miles at the time), there were no major problems - just normal maintenance.
We have 60,000 miles on our 2007 DGC, and, except for one set of front brake pads and oil changes, it's hasn't needed any other work (know on wood).
That said, I would be hesitant to buy any vehicle with that number of miles on it unless 1) it was a really good deal, price-wise, 2) I had a good sense of how it was driven and 3) how it was maintained. Also, it's good to know why someone is getting rid of an ostensibly good running vehicle.
I bought a Merc Tracer for $2500 for my boys some years ago that had 125,000 miles on it. My wife worked with the owner who was going to for Africa for couple of years. I also bought a 10 year old 87 BMW with 125,000 miles for around $2500 who's owners were being transferred to Key West. Again, my wife knew the owners, plus they were able to provide many of the service records. I still have, and drive, the BMW.
So yes, miled-up vehicles can be good deals. You just have to be cautious and go into the deal with eyes open to fact that you may have to lay out a thousand dollars or two to fix something major or even just to catch up on neglected maintenance.
Karen
