How much does the TSB repair for squeaky wheel cost?
 iamyourdemize
                    Member Posts: 2
iamyourdemize
                    Member Posts: 2
                    http://www.fcsdchemicalsandlubricants.com/fad/tsb/06516.pdf
Does anyone know how much that should cost to get done? I have a 2003 V6, not under warranty.
Draw out as much fluid as possible. Refill with fresh fluid. Drive the car up and down your street, making sure to make several "lock to lock " turns of the steering wheel. Take the car back home, suck out the fluid, and repeat this procedure two or three times. Replace the strainer after the last flush and you're done.
