Electrical problem: stalling immediatly after starting
96 town & country LX 3.3 300k
when I turn the accessories on, I get my usual "service engine soon" light. other then that, I don't get any of my gauges, and the odometer and trip meter don't light up. The car starts fine (aside from the lack of activity from the guages) except it immediatly shuts off (like if I were to kill the ignition). I've had this happen twice before, and by disconnecting the battery for a while, it solved the problem. But it's happening more and more.
Any ideas on what could be the problem? Thanks,
David
David
This may sound like a simple-minded request but the dashboard trim is all plastic and probably becoming extra brittle with age. I need to remove the trim around the instument cluster so as to remove it for the solder repair or replacement so widely discussed in this forum. Since I cannot see any screws, it probably just pries off but I've tried gently in several places with nothing yielding. Can someone please help out by explaining exactly how to pop this trim off without breaking it. Perhaps other members are similarly frustrated also.
Search one of the other Chrysler/Dodge minivan forums here for this topic.
Try changing your PCV valve first, though it could be something more serious like a flaky fuel injector or a bad piston ring,
Does the van run OK? Any noticeable drop in gas mileage?
