Ford Expedition 4WD Problems
 mudhopper2
                    Member Posts: 2
mudhopper2
                    Member Posts: 2
                    I have a 98  that the 4x4 indicator lights will go on but it will not be in 4 wheel drive.  I put all new ball joints in and after that I noticed 4wd was not working.  Is there something I could have messed up doing that?  Or do you think the transfer case shift motor just happened to go bad, and if so would the indicator lights still work? they dont blink.  thanks for any help.
See Also
Edmunds Answers: Expedition 4wd Questions
See Also
You are seriously damaging your wheel hubs in the front if you continue to drive on dry pavement in 4x4.
Mark.
Either way, if it is in the state all the time, I would stop driving NOW!!
Could you please elaborate on how did you resolve this problem? I am having the exact same problem and can't seem to find a resolution.
Fumes seem also to be either entering the cabin in the rear cargo area, or gathering there and being distruibuted by the rear heat-cool system ventilation fan through the ceiling air ducts.
Ford has tried repeatedly to diagnose and fix the problem, but seems to be having trouble identifying the cause. They are willing it fix it, but so far have not figured out the cause. Has anyone else had this problem? Any suggestions?
I need help. I have new car that I cannot drive or take my kids in safely.
Thanks for any ideas.
Thanks for the tip on giving the transfer case a pop. I had read that elsewhere too. I did not get to that point in troubleshooting but was able get the 4WD working today. I rechecked the transfer case fuse, as well as checked all of the GEM (generic electronic module!?) fuses. The circuit for the 4WD selector goes through the GEM. All fuses looked okay, but there must have been a bad connection in there cause after checking and reinserting the 6 or so fuses, I started her up the AWD and 4Hi are working. yeah!! Just goes to show - start with the simple stuff first!
Fast forward to today. I finally decided to take a look at it. Here is what it does: Select A4WD on ice. Get rear tire spin only, then the 4x4H light illuminates for some reason. Select 4x4H and i hear solenoid by the seat belt click. 4x4 indicator illuminates on the dash and only have rear tire spin. Put trans in neutral, foot on brake, select 4x4L. Transfer case engages in low range and 4x4L indicator illuminates. Rear tire spin only. Also crawled under and listened and felt the transfer case shift motor and it seems to be working when someone switches from 2HD to 4x4H
Now today, I am hearing a noise like a rattle ONLY when 4x4 is selected and while I am getting rear tire spin. I thought it was coming from transmission/transfer case area. My wife says it was coming from the front of the truck (hubs?).
I changed the transfer case fluid with appropriate fluid and only then, during a test drive, the ABS light and (red) brake warning light came on. Also received a "check control trac" message in the MID.
I am thinking that it may be the hubs but I was told that if they fail (loss of vacuum by hose or seals) that they fail in a locked position so I should still have 4x4. However, this summer, I did notice a clicking sound from the hubs when turning the wheels sharply in either direction in 2WD but no drive line bind like you get with an operating 4WD system.
Any thoughts? I m at a loss. Tear apart the hubs or should I pull the transfer case and inspect the internals? Could this be a speed or ABS sensor?
The motor is a plug and play and unbolts pretty easliy. You could take it out and see if there is anything going on.
thank you..
John
Is that true..?
Also, ABS, VSC and TC are typically disabled with the F/R coupling engaged, so those wouldn't be the causative noise factor.
