Jeep Cherokee (XJ) Cruise Control Does not Work
I have a 2001 Jeep Cherokee Sport 4dr 4x4 with only 54xxx original miles on it. The problem that I am having is the Cruise Control and the Horn does not work.
I do not get any light on the dash that says the cruise control is on or anything.... it just plan does not work.
The air bag appears that it might have been set off in the past, being that I am the second owner I am not sure. Being that, I took apart the steering column and the steering wheel to make sure that everything was plugged in and not disconnected, from what I saw everything seemed to be plugged in.
Does anyone know how I can fix my cruise control? I have tried to see of there were any similar discussions but I couldn't find anything in regards to the regular Cherokee.
I would really appreciate any help because you don't know how much you miss cruise control until you don't have it.... epically when you have to drive back and forth between Tulsa and Houston almost twice a month.
If you open up your hood you will see your battery to the left. If you follow the inner panel, left to the battery, you will see a hose that connects to the servo control; goes from round looking to pointed. It has a gray hose that goes from the servo down past the battery and down to the bumper where it connects into the vacuum reservoir. Check that hose and make sure it is not damaged.
Hope this helps. Good luck!!
