Honda Accord Hybrid IMA Batteries
                    I'm concerned with the drainage of battery power during day to day driving.  Is it normal for the battery to drain to the point where 3 or 4 lines are showing during a 15 minute drive time?
Regarding the IMA batteries, is there a way to charge these batteries at home?
Other than the batteries, the Hybrid has been a pretty good car. As long as all regular servicing has been taken care of during normal intevals, this car will take care of it's owners.
1
Can you charge the battery at home? No. There is a charger available for 2000-2006 Honda Insights, but not for other models yet.
Please keep us posted with updated info. on Accord Hybrid IMA battery. Thanks.
Thanks for your instruction. Do you think the Accord IMA battery should last long for many years? I heard Toyota hybrid battery lasts very long for 150K - 200K miles.
Also, on a road trip doing 75, I watched the miles per gallon drop from 34 to 24... I was horrified!!! The Honda dealer has no answer to this, and I'm leaving on a 2,000 mile road trip in 3 days. Help!
IMA battery and engine lights came on 2,000 miles past warranty. Had the battery replaced at the dealership at a cost of $3,500. Was reimbursed $3,000 through American Honda Motor Company. The $500 is still pricey but much better than what I originally paid. The car was purchased and resides in FL. Not sure if special consideration given due to the extreme heat in our area.
Thanks for posting here. I've been looking all over the place and have been trying to find people in similar situations and I'm curious how you were able to get your IMA battery replaced under warranty.
I just got back from my dealership and they ran my VIN only to tell me that it's not covered under warranty. If you can provide insight or some advice on how I can get my IMA battery replaced on my 2005 HAH that would be greatly appreciated.
Many Thanks!
JD
I took it to the dealership where the diagnosis was failure of the IMA battery, which was replaced under warranty. After doing some more reading about Honda's Civic Hybrids, I decided to ask if they were using a remanufactured battery, and turns out they are. How the batteries are remanufactured could not be satisfactorily answered. I asked if they replace all battery cells or just the failed cell, and I could not get an answer from the dealership or Honda's Customer Service. It seems there is no other option, as new batteries do not exist.
So I pick up the new car and it drives like a Prius and is getting the milage of a minivan (28 mpg after 2 hrs of highway driving in no traffic with average speed of 45 mph). In particular, the electric motor no longer activates at low speeds (< 25mph), and does not help at low speeds, where the performance advantage of the electric motor is greatest (ie high torque at low RPM). I called the dealership to see if any software was loaded, and it was. I'm thinking that this software patch could be similar to what Civic Hybrid owners were complaining about? Where the software patch reduces the battery usage to preserve battery life, but at the expense of performance and acceleration.
If anyone else has noticed this on their HAH please post, as I would like to compare experiences and resolutions.
Scott
You can take your car to Auto Zone or someplace like that and tell them that the IMA light has gone on; they have a tester and can look it up. That's how my battery problem started, too. Saves you that trip to your dealer, because they will probably have to order the battery and won't have it for a day or 2. Good luck!
Disclaimer: The HAH battery pack contains a high voltage source capable of fatal electrocution. Do not attempt any repairs or contact with the battery without proper training and knowledge of this system. I accept no liability for you working on your HAH battery pack.
I learned how to completely discharge my battery and did so. I purchased all the necessary equipment and wiring to permit battery charging (reconditioning). Here's what I did:
Honda Accord Hybrid (HAH) Grid Charger
1.Purchase BioRad 300 power supply to use as a charger for HAH-eBay
2. Print BioRad manual for reference--online
3. Purchase power supply (charge cable) that allow power transfer to HAH
4. Purchase polarized power socket and plug.
5. Purchase diodes, fuses and fuse holder.
6. Purchase power wire and terminals to connect battery and power socket.
1. Connect the (+) and (-) leads of the power wire to the correct places on the pack. Place a diode as close as possible to the (+) terminal connection. Attach the inline fuse holder and fuse to the socket connection designated (+). The (-) lead only requires a terminal connection, no fuse or diode; attach to the socket connection designated (-). Carefully confirm connections are correct.
2. Charge cable from power supply requires modification. It is equipped with banana style plugs on both ends. The red lead is (+) and the black lead is (-). Cut off the plugs on one end and attach red lead to the plug terminal that matches the socket connection designated (+). Attach the black lead to the plug terminal that matches the socket connection designated (-). Confirm power output polarity is correct.
CHARGING
1. Clear any trouble codes if they exist. Remove the key from the ignition.
2. Plug the charge cable into the BioRad 300 power supply; connect to the polarized socket in the trunk.
3. Power up the BioRad 300 and set amperage to 400ma. Charge for minimum of 10 hours. Repeat charging on subsequent days for a total of (3) charge sessions.
4. It’s a good idea to reset the ECM by the fuse removal procedure. This allows system to recalibrate on the new state of hybrid battery.
5. Note: A single 24-30 hour charge may be required to completely balance all the cells in the pack. If IMA light continues to be set, several or all of the cells may require replacement.
6. Some owner’s grid charge their cars every night. I’m hopeful I can rebalance my pack and keep in top shape with monthly or weekly charging.
7. I charge my pack 24 hours every 3-4 months or when my IMA light comes on. I'm closing in on 130,000 miles and 18 months using this system. As far as I know my battery is original.
8. My total cost was less than $200.
Check out these sites for more: ecomodder.com and http://www.greenhybrid.com/discuss/f51/battery-refurbish-process-imax-b6-27116/i- ndex9.html.
My solution applied everything I learned about Civic Hybrid to my Accord Hybrid. Unfortunately, little grassroots support exists for the HAH because it's a luxury model only made for 3 years. The HCH is much less expensive and still in production. Good luck with your HAH's
Thank heaven for this forum!!!
This Asian man saved me $850. At first I thought it was skipping steps, when I realized he really did show where everything was on it.
http://www.youtube.com/watch?v=lnzQ7My--nk
If your harmonic drone sound is most apparent between 1500 and 1700 RPM try this.
1. Accord Hybrids with Navigations system: Turn the ignition switch to ACC (1) or ON (II)
2. Turn the Audio Unit off. (Radio on and Off button, push to off)
3. While holding down the upper part of both the "CH/DISK" and "SEEK/SKIP" buttons simultaneously, press the VOL/Pwr knob.
This will place it in Diagnostic mode...DIAG will appear in the upper window above the Nav unit.
Now while the engine is stopped and while in DIAG mode, turn the ANC ON and OFF by pressing the SCAN Button, you may have to push SCAN button ON and Off a couple times... While in the OFF mode, This will be displayed in the upper window above the Nav unit..... a low frequency hum (50HZ should be heard. While this low frequency tone is sounding turn the engine on and the sound should go away. IF it does your ANC is working and now is reset to the on position automatically. Now drive your car and see if the low frequency drone is gone!
If you do not have the NAV unit follow this procedure.
1. Turn the ignition switch to ACC (1) or ON (11)
2. Turn the audio unit ON.
3. While holding down both the "Preset1" and "Preset6" buttons simultaneously, press the AUDIO PWR knob.
4. "DIAG" will appear on the audio unit display to indicate you have entered the self-diagnostic mode.
NOW, while in Diag mode turn the ANC ON to OFF by pressing the #1 button, A LOW
frequency hum (50HZ) should sound for up to a minute. While this low frequency HUM is Sounding turn the engine on and the HUM should GO AWAY. Now drive your car and see if the low frequency drone has gone away!
There have been numerous cases where the ANC appears to toggle off all on its own.
I have 120,000 on the car now and am wondering if it's time to have the struts looked at. I asked at my local garage and they want $1,600 for all 4. GULP. Is that realistic? Gosh, I hope not!!!
The above link will lead you to a site to purchase the part. The part is item #9. Look on you Tube for the installation instruction http://www.youtube.com/watch?v=w6IKK-C1-QQ
Does anyone have or know where I can obtain the specifications to the HAH battery pack? I want to make my own grid charger, but I don't have any information on the batteries, what is the maximum voltage they can be charged to, how many cells/sticks the pack holds, how many individual cells/batteries are in each stick, what are their voltages etc. Without this information, I am afraid to try and grid charge as I don't know what is the max voltage and amperage I should be setting the charger to. I really wish someone who has built a grid charger for the Accord Hybrid had taken the time to document the process, details, connections so that those of us catching up can follow in their footsteps. I am frustrated with the lack of support for our car as it applies to DIY charging/refreshing of the battery.
Here's one outfit that lists the battery for $1,700 (plus installation); a net search should turn up some others, and hopefully one or two won't be that far from you. Be worth getting a quote if nothing else.
We did the math once and not counting the price of the replacement batteries when they eventually fail a person had to drive over 150,000 to make up the difference in the original price.
And, they didn't get that mush better mileage than a non hybrid.
Still, we sold a few.
On the other hand, $3,400 is just six or seven car payments, and you get to continue driving a car that you know very well and one that may fit you like a glove.
Have gone back to Honda Customer Service, even escalated and got a response from the executive office and they won't do a thing for me. Any suggestions on how to get the problem resolved without being forced to spend $5K for parts and labor? I live in the NY metro area.
Old thread here but hopefully some has info for me.
Dealing with the same IMA battery replacement needs as most from this thread and debating between an independent shop (greentec auto) vs going through Honda. Would cost roughly $1200+ less to go through Greentec who has 11 yrs in the industry and 24 shops nationwide. Main concern is safety and making sure that there is no know issues going with an independent shop and their batteries. The battery sits right behind the back seat which is right where my young kids are strapped into carseats. Equivalent warranty as Honda and favorable reviews of the business online, anything else I should be thinking about / concerned about / or might be missing? Am I overthinking it too much?
Thanks for any info and help!
