Toyota Avalon Water Pump Question
Hello. I have a 2002 Toyota Avalon with 94000 miles. I just had the Timing Belt, Front Engine Seals, and Water Pump replaced (as preventive maintenance). The Toyota Service Tech told me that they change out your coolant when they replace the waterpump. However, I noticed today that the coolant container is only filled to low. I called the service tech at Toyota and inquired about this and was told that the container is simply an "overflow container and it is not necessary to fill this to the Full line." Is this correct or should I take the car back in and ask them to fill it to the full line. My bill shows that I was charged for a gallon of antifreeze. Please help. Thank you.
If you still get an argument, ask him to look at the containers on new vehicles, they will be full!
I asked the service tech about the coolant level and he said it must be filled to lower limit when the engine is cold. If not, when the engine is hot and the coolant expands it would spill over and create an unpleasant mess. His explanation makes sense and sounds reasonable so I'm inclined to believe him.
By why does it cost so much to replace a timing belt and water pump? My daughter had the same things done to her 2002 Civic in Atlanta and it only cost $550.
As I look through some of the other coments I notice the water pump is mentioned on some of the responses. Should I do a water pump at the same time?
The dealer did not mention a water pump.
Jack
I have an 02 Avalon. In May, I took it in to the Toyota dealer to have the timing belt changed because it had 93000 miles on it. They quoted me about 430.00 to do just the timing belt. But, they told me it was a good idea to have the water pump and front engine seals replaced at the same time because these are also very costly and would be a lot less if done at the same time as the timing belt. They said that it cuts down your labor cost because it is difficult to reach these items in the engine. I guess they have to remove a lot of things just to get to them. I'm not a car expert so I called a few other places just to make sure they weren't feeding me a line to get me to spend more money. Long story short. I had the timing belt, drive belts, water pump and front engine seals done for 766.00. Hope this helps. Good luck with your timing belt.
Big Roz
I'm going to take your advice and have it all done.
Some years ago I had a timing belt done at the Mitsubishi dealer in my area on my son Mits 3000GT. 6 mo. later the water pump froze up and we blew the engine.I was told by everyone I spoke to after you don't do a belt without doing the water pump on a Mits. I don't want to go through that again.
