AC blower not working
in Pontiac
I have a 1994 Pontiac Bonnaville the AC blower stopped working. I can feel cool air coming from vents, but the blower fan will not operate.
If I recall, the resistor pack gives the lower speeds and HIGH speed is a relay that connects directly to the battery power in the relay center. So if the resistor pack burned out you lose 1,2, or 3 speeds and the HIGH still works. Or if the relay or fuse burns out on the HIGH speed the others still work.
So carefully remove the power connectors and check the motor. The relay center can be raised by removing two screws holding it and then it has some slack and can be raised a little to give work room.
If you replace the fan motor, be careful with the plastic around the housing; it's been hot a lot of years with motor heat and becomes brittle.
If the motor is okay it is probably your blower motor control module that's in the blower housing where the blower leads go. It's under the relay panel. The relay panel has two bolts and can be pushed up some to get room to take out the blower control module. It works like the resistors in old style systems; it sticks into the air stream for cooling.
The carpet may be in the way of removing the fan, so pull it down away from the firewall and your should be able to wiggle the motor and squirrel cage out.
There may or may not be a rubber tube that runs from the HVAC back to the motor portion to cool the motor. Motor may be a little heavy to hold and lift while getting the 3 screws started--I used junk between the floor and the motor under the blower to help hold it up in place.
