Need advice
                    In need of a truck that can pull 3 horse trailer(no camper) in Mts. Also will be used as a daily driver to transport my children in booster seats. Looking for something under $10k. V10, V8, di or gs, HD or SD. Whats your opinion?
What year tailgates are compatible?
:confuse:
have heard that being a problem also you say one hose is hot and the other
is warm. Is the hot hose hard as in under pressure and the warm hose is it
hard?. Check the hardness of these hoses in clod engine and operating
conditions for good pressure in hoses. also might have to check duck work
could be a disconnected close to the core. Many things to check before
pulling water pump. I would disconnect the hose coming from the water pump
and see how much pressure it has also.
2. Check to make sure the thermstat is not a by-pass thermostat
