2005 Equinox radio swap with newer model
                    Has anyone swapped out their 2005 radio for a newer equinox model that has the mini jack plug for an ipod.
Does a new model also fit the 2005, like a 2007 radio fit a 2005 model. Any ideas or suggestions
You say that it works o.k., so it must be "unlocked" by a code from the dealer but you are supposed to have this code in your possession.
Here is more explanation about a "locked" radio.
The radio uses a "radio lock" that engages automatically whenever you cut power to the radio.
This feature helps to protect the radio from being used if it is ever stolen. In this respect it acts as a theft deterrent.
The thinking is simple: even if a crook were to steal the radio, it would be useless to that person since without the unlock code from the manufacturer, the radio cannot be operated.
Unfortunately, this means that if you lose the radio code, you will need to have your radio reset by a General Motors dealership.
If you do have the code, you can reset the radio yourself.
Here is the way to "unlock" your radio with your personal code;
Step 1
Turn the radio on by pressing the "power button" on the radio console.
Step 2
Wait until the radio flashes "CODE" on the display screen.
Step 3
Press in your personal code on the radio console number pad.
Step 4
Wait for the display screen to stop reading "CODE" and return to a normal display. This will reset the radio and allow you to use it once again.
Medanic
