'04 Sienna not starting properly
My '04 sienna has 40k miles and is not firing up right away like it used to. I've had the battery checked at an autopart store and it is working properly so i suspect it's the starter since it's making some clicking noise (like if the battery was dead) when it doesn't fire up right away.
The mechanic is telling me that i can't replace the starter with a refurbished one cause they only last 1 year and should go with OEM Toyota part at $300 + $170 for labor so total to replace starter will be in the $500. Does this pricing sounds reasonable?
It's weird that the starter will go bad at 40k miles but if it has to be replaced should i follow the advice of the mechanic or go with a $70 one remanufactured?
I've only done the oil changed every 5k at dealer since i bought it new so could
it be that it needs a tune up and that's the spark plug or else that's going bad?
I also noticed that the side doors are not closing automatically all the times anymore, mostly when the car has not been running or the engine has been turned off. Sometimes i'll push the button and they would open and close sometimes not, both issues started around the same time.
Battery was the issue after all, replaced it and everything is back to normal now.
Thank You!
First, similar to above it takes about three seconds of turning the key for the car to turn on. Is this a problem or just something i have to live with?
Second. I live in Virginia, and it has been on and off cold here the last few days. Today it snowed. Tonight and in the past cold days when i have gone out to the car to open the doors (rear sliding) they have been unable to open. Whether the electric is on or off, the door will what seems like unhitch, and then it will not open or close. The problem is that i can not lock the car because the car thinks the door is open - or if it thinks it closed, lets me lock the car and eventually the alarm goes off when it thinks the door is open. I would think this is a problem caused by the cold, but i have taken the car to vermont on many occasions during the winter (in colder conditions) and never had this problem, even when the car has sat for longer.
I am looking for a suggestion on how to go about handling this. I believe the car is under extended warranty until 70k miles.
