2005 Subauru Baja trailer wiring problem
I went to hook up my trailer the other day and found that the lights on the trailer didn't come on. I then hooked up the trailer to another vehicle and the trailer lights lit up just fine.
The problem seems to be with the Baja and not the trailer. I've heard that it could be a ground problem but where do you start? Is there a test kit of some kind out there to help me diagnose the problem? Any ideas would be most appreciated. Thanks!
I do recall a white box that sort of housed the wiring harness for mine. Maybe that went bad?
I have photos of what Subaru's harness looks like, and could e-mail to you if you'd like.
thnx
Here is the grommet that seals the hole that sends the wiring to the outside. It was in the spare tire well of my 98 Forester.
I secured the wire with zip-ties to the hitch itself.
It was plug-n-play, no splicing, no wiring. All OEM Subaru equipment.
