2009 Chevrolet Malibu Desired changes and gripes
e_net_rider
Member Posts: 1,380
09 Malibu LT2 I-4 AT-6 less than 500miles.
1) The test dummy obviously did not have to get in or out of the vehicle on his own. a)Move the door pillar back a couple of inches. I'm only 5'8". b)Use a real tilt that moves the steering wheel up out of the way.
2)Change the dash vents so I can point them above my head where the cold air will fall on me and not blow in my face.
3)Make the steering wheel a couple of inches larger in diameter for comfort.
4)Place the speedometer so that it can be seen without being blocked by steering wheel when it is located at best comfort position.
5)Suede seems to get hot after riding on it for awhile. I'd prefer real leather.
6)When you move up from the base wheel/tire, I'd expect a better tire. Firestone FR710 does not seem to be best tire for this car. Often has too much road noise. Properly inflated, they ride a bit hard. I think handling and response would improve with a better tire, but it is not bad. I haven't driven in rain yet, so I can not comment on standing water or wet roads yet.
7)I just noticed the weights attached to the wheel. These are not the balance weights you would normally see attached to the rim, but on the inner side of the wheel. I am not sure if they are there to balance the wheel or the tire, or how they are even attached. If they are there to balance the wheel, I can only hope GM did not accept that kind of quality standard for other parts. If they are there to balance the tire, then these tires should have been rejected. There are massive amounts of weights. My experience has been that with new quality tires, they may not even have to add any weight to balance them.
8)Some padding on the door armrest would be nice. This texture surface molded plastic is like sandpaper. And it appears that it may not be solid color, only dyed on the surface. I see a few places where white seems to be showing through.
9)Add duct for rear seat. It would help with overall cool down of interior and comfort.
What problem do you have with it? "the ... door has to be on the drivers side" -- why?
In what ways is the new Malibu "much improved over the previous
models?"
Better MPG? More cargo and passenger space? Easier to get in and
out? Better reliability? Looks (for Heaven's sake)?
Did you own any Malibu of the previous generation (2004-2008, sans
"Classic")? What models are you comparing the 2008+ Malibu with?
models?"
As you are probably aware the two previous gen Malibu's were rental car queens. In fact there was a time when I think the second gen was the fleet queen for National and Enterprise. Seemed to have more of them than even the "classic" you referred to. I didn't care for the first gen malibu, felt the 2nd gen was a nicer car other than its looks, but it rode my [non-permissible content removed] over every tar strip on the Interstate. I test drove, but didn't buy the current Malibu. I felt it drove smoother and more quietly than its predecessors, and looked a whole lot better inside and out. However, at the time at least I could get a better deal on a Camry and a much better deal on the Fusion. Honestly, I don't know how you cannot view the current model as superior to the two prior generations?
Er... Let's not confuse the two previous generations of Malibu (2004-,
a.k.a. "Classic", and 2004+). Nothing is shared between them, as far
as I understand.
Second, in my area, I could get Honda Accord at Enterprise, but not
Malibu 2004+. Impala, yes, but not Malibu.
So? Queen or not queen -- how does it speak about the car's quality?
What car exactly do you mean here? Year and the trim level?
My Malibu 2005s are as smooth as silk, anywhere.
It drives differently, perhaps better. It looks better inside.
Outside? I don't like its truck-like nose. Impala and HHR look
better, in my opinion. To my eye, Malibus 2005-2008 look great -- but
this is a matter of taste.
I meant one generation only, 2004+-2008.
I cannot view Malibu 2008+ to be superior to that generation, because of:
* Worse MPG.
* Much less passenger and cargo space.
* No Maxx-like trim.
* What I read about this car from the owners, doesn't inspire my
confidence in the car's reliability.
The car just doesn't seem as practical as the previous generation
Malibu. Or, and on a highway, I pass the new Malibus more often than
they pass me.
No disrespect to current Malibu owners: if you are happy with your
car, I wish you to keep enjoying it, but when I was thinking about
buying another car this summer, I didn't even consider the new Malibu.
Of the old Malibu's, I own three at this moment: a 2006 Maxx was added
this July.
To be honest with you, sometimes, when I get to the pump, I have to make an effort to recall where the fuel tank door in my car is (my previous two cars had it on the driver's side), I can live with either side, but the current arrangement seems a bit more logical to me: e.g. it's easier to get out of the car in a tight spot without hitting a pump guard with the door. Anyway, it's just a matter of taste for me, don't feel it "has to be" one way or the other. And I can't see how having the tank door on the driver's side would help you in "bad surroundings". I think the surroundings will get you if they want to, no matter where the opening is...
Reason is, I'm convinced there is likely a much better tire for this vehicle. The slight vibration that feels somewhat like a flat spot and seems to vary with road and speed might be a balance issue. I would not have suspected this vehicle for having a very firm frame, such as was the issue with some Cadillac and the Olds Aurora. It fielded so many complaints that Hunter created the "road force balance" machine. The frames were so sturdy that a slight imbalance would be felt and conventional balancing would not do the job. This machine spins the tire like most machines, but applys pressure to the tire as if it is on a road surface. The pressure is adjusted according to the weight of the vehicle, so you get a truer real world balance. I will be having a talk with the dealer about this. And that after 6 weeks they have not yet titled the vehicle so I can transfer my tag. On the other hand, I've been receiving mail from GM, OnStar, and XM welcoming me and congratulating me on my new Avalanche.
Thank you for your responses.
It is important to be aware of your surroundings at all times these days, and a gas station should be one of the safest places. It might be real busy so there are plenty of people around. If not, just make sure the attendant is paying attention and not stocking shelves or something. Go inside first if you feel unsafe and ask the attendant to keep eye open. Remote in hand, hitting panic button should draw enough attention. Video cameras might be helpful, but it is surprising how many idiots do something in plain view of them.
My youngest got married yesterday. They had two nice metal trellis decorated for the outdoor wedding. We moved them to the reception and they were placed at the main entrance. Packing up everything at the end of the night, they were gone. One of the building employees told me someone took them earlier. Suspicious, I took a look around since the kids might want them for their yard, something from their wedding. Glancing up, their are two of those newer 360 degree cameras. Got cha!
@Goatee: Huh? The Fusion has driver side filler, and capless, so less hastle, so why would the Civic be better for pumping gas?. (Waiting for gas theives to figure it out...) I really like the new Civic's, but wanted to go with a mid-size rather than compact, so got a Fusion.
