Mazda CX-9 Passenger Floor Leak
2008 CX-9. First problem was when the car turned off the HVAC fans turned on for approx. 1 minute. The dealer replaced a relay and it fixed that problem.
Now when the wheel is turned (about a quarter turn or more) the fans turn on, and the passenger floor mat and carpet under the mat is soaking wet. The dealer stated that they don’t know what’s wrong and we should try to keep the fresh air setting closed during rainy days!!!
Any input would be appreciated.
Jim
Jim
I have a 2008, not a single problem you indicated.
I leave my A/C to auto since I got it two years ago.
2 - Fans coming on when turning the wheels...you definately have an electrical problem, have it looked at by the more capable and willing dership.
3 - Carpet wet...sounds like your drain tube for the evaporator is either sitting inside the cabin instead of extending all the way out into the outside, or the drain tube is clogged up not draining properly and water accumulating inside the evaporator case and seeping through into the carpet.
Going to a new dealer on Monday, I'll post the results.
Jim
The first time the dealer flushed the sunroof drain lines and lots of leaves and dirt flushed out. Took it home and same problem. You could hear the water shifting in the fan unit as you turned just enough to allow the blades to contact the water and throw it in the cabin. Another dealer said there is a hidden drain line under the exhaust that services the A/C evaporator line. The dealer had to put a hanger up there to finally clear it and they got a shower. All is fine now. Lesson: Don't park your CX-9 under trees apparently. Not sure if the owner did this with his sunroof open, but who knows. If you garage them, you shouldn't have a problem, so they say. But if your cx9 is in dusty, dirty, leafy conditions, you may want to flush the lines from your sunroof annually.
30K service is a waste of money.
Do mantanence by the schedule in the owners' manual.
Dealer loves those XXk service package - big ripoff.
Especially the cabin air filter. Dealer charges you $80 easily, when it actually costs about $10 for the part, and 1 minute to install it.
Water problem?
I don't have this problem, but I do clean debris regular for any vehicles I own(ed).
BTW, the relay part number is G115-67-730, you will need two of them one for the front blower and one for the rear one.
Good luck!
