Various 2003 GC Issues
                    I purchased this a few months back and I'm having various issues with it.
1st - The 4WD selector seems to be arbitrary. It doesn't work smoothly and it can be indicating 2WD but you can feel it's in 4WD or PartTime 4WD OR vica versa: it can be indicating it's in 4WD or Partime and it's actually in 2WD.
2nd - it's going through front driver side tires like crazy. The tire wear is significant on the outer edges - almost to the steel belts. And there is a definite shimmy (not the death wobble). A constant shimmy and pull towards the front driver side tire. To maintain a straight path the steering wheel has to be turned towards the right approx 10~15 degrees.
Cringingly waiting your replies - Smokey3686
