Isuzu Axiom Error Codes
On Isuzu Axiom '02. error code 401 keeps appearing. Have changed Oxygen sensors 4 and EGR valve. Appeared again. No vaccuum leaks. Any other helpful tips?
SUVs and Smart Shopper
So, it could be the coil problem that's causing the cat to go bad. If I can find the original paperwork, I'll see if it has a more detailed explanation of the problem.
he cleaned EGR passage, ports and changed EGR valve but had no luck. So, I took it to the dealer hoping they would know exactly what the problem is, and explained the supervisor about the problem. Dealer did exactly what my mechanic did cleaning EGR ports, and at the end I was told they don't know what is causing the problem, so they want to see if its from catalytic converter or something else. At this point I already spent $700 and its driving me crazy. Does anybody know what could be the problem? Plz help
Did they check the catalytic converter yet? If yes, status?
I would check the wiring just in case there's a short somewhere, check fuses,
P0101
MAF System Performance
P0102
MAF Sensor Circuit Frequency Low
P0103
MAF Sensor Circuit Frequency High
P0106
MAP System Range/Performance
P0107
MAP Circuit Input Low
P0108
MAP Circuit Input High
P0112
IAT Circuit Input Low
P0113
IAT Circuit Input High
P0116
ECT Circuit Range/Performance
P0117
ECT Circuit Input Low
P0118
ECT Circuit Input High
P0121
TP Sensor System Performance
P0122
TP Sensor Circuit Input Low
P0123
TP Sensor Circuit Input High
P0125
ECT Insufficient Coolant Temperature For Closed Loop Fuel Control
P0131
HO2S Circuit Voltage Low Bank 1 Sensor 1
P0132
HO2S Circuit Voltage High Bank 1 Sensor 1
P0133
HO2S Slow Response Bank 1 Sensor 1
P0134
H02S Circuit No Activity Bank 1 Sensor 1
P0135
HO2S Heater Circuit Malfunction Bank 1 Sensor 1
P0137
HO2S Circuit Voltage Low Bank 1 Sensor 2
P0138
HO2S Circuit Voltage High Bank 1 Sensor 2
P0139
HO2S Slow Response Bank 1 Sensor 2
P0140
H02S Circuit No Activity Bank 1 Sensor 2
P0141
HO2S Heater Circuit Malfunction Bank 1 Sensor 2
P0143
HO2S Circuit Voltage Low Bank 1 Sensor 3
P0144
HO2S Circuit Voltage High Bank 1 Sensor 3
P0146
HO2S Insufficient Activity Bank 1 Sensor 3
P0147
HO2S Heater Circuit Bank 1 Sensor 3
P0151
HO2S Circuit Voltage Low Bank 2 Sensor 1
P0152
HO2S Circuit Voltage High Bank 2 Sensor 1
P0153
HO2S Circuit Slow Response Bank 2 Sensor 1
P0154
H02S Circuit Insufficient Activity Bank 2 Sensor 1
P0155
HO2S Heater Circuit Bank 2 Sensor 1
P0157
HO2S Circuit Voltage Low Bank 2 Sensor 2
P0158
HO2S Circuit Voltage High Bank 2 Sensor 2
P0160
H02S Circuit Insufficient Activity Bank 2 Sensor 2
P0161
HO2S Heater Circuit Bank 2 Sensor 2
P0171
Fuel Trim System Lean Bank 1
P0172
Fuel Trim System Rich Bank 1
P0174
Fuel Trim System Lean Bank 2
P0175
Fuel Trim System Rich Bank 2
P0201–P0206
Injector Control Circuit Cyls. 1–6
P0218
Transmission Over Temperature Condition
P0300
Engine Misfire Detected
P0301–P0306
Misfire Detected Cyls. 1–6
P0325
KS Filter Module Or Circuit
P0327
KS Sensor Circuit Input Low
P0335
CKP Sensor Circuit Malfunction
P0336
CKP Sensor 58X Reference Signal Circuit Range/Performance
P0337
CKP Sensor Circuit Frequency Low
P0341
CMP Sensor Circuit Range/Performance
P0342
CMP Sensor Circuit Input Low
P0351
Ignition Coil ‘‘A’’ Primary/Secondary Circuit Malfunction (2.2L)
Ignition Control Circuit (2.6L)
P0351–P0356
Ignition Control Circuits 1–6 (3.2L)
P0352
Ignition Coil ‘‘B’’ Primary/Secondary Circuit Malfunction (2.2L)
P0401
EGR Flow Insufficient
P0402
EGR Excessive Flow Detected
P0404
EGR Sensor Circuit Range/Performance, Stuck Open
P0405
EGR Sensor Circuit Low
P0406
EGR Sensor Circuit High
P0420
TWC System Low Efficiency Bank 1
P0430
TWC System Low Efficiency Bank 2
P0440
EVAP System Malfunction
P0441
EVAP System No Flow During Purge
P0442
EVAP System Small Leak Detected
P0443
EVAP System Purge Control Valve Circuit Malfunction
P0446
EVAP System Canister Vent Blocked (Except 2.2L)
EVAP System Canister Vent Control Circuit Malfunction (2.2L)
P0449
EVAP System Vent Valve/Solenoid Circuit Malfunction
P0452
EVAP System Pressure Sensor Input Low
P0453
EVAP System Pressure Sensor Input High
P0461
Fuel Level Sensor Circuit Performance
P0462
Fuel Level Sensor Circuit Input Low
P0463
Fuel Level Sensor Circuit Input High
P0480
Cooling Fan 1 Control Circuit
P0481
Cooling Fan 2 Control Circuit
P0501
VSS Circuit Range Performance
P0502
VSS Circuit Input Low
P0505
Idle Control System Malfunction
P0506
IAC System RPM Low
P0507
IAC System RPM High
P0532
A/C Refrigerant Pressure Sensor Circuit Input Low
P0533
A/C Refrigerant Pressure Sensor Circuit Input High
P0560
System Voltage Low
P0562
System Voltage Low
P0563
System Voltage High
P0601
PCM Memory Checksum Error
P0705
Transaxle Range Switch Circuit
P0706
Transaxle Range Switch Performance
P0712
TFT Voltage Low
P0713
Transmission Fluid Temperature Voltage High
P0719
Brake Switch Circuit Low
P0722
Output Speed Sensor Circuit No Signal
P0723
Output Speed Sensor Circuit Intermittent Signal
P0724
Brake Switch Circuit High
P0730
Gear Ratio Improper
P0742
TCC Circuit Stuck On
P0748
Transmission Pressure Control Solenoid Electrical Fault
P0751
Transmission SS ‘‘A’’ Performance Or Stuck Off
P0753
Transmission SS ‘‘A’’ Electrical Fault
P0756
Transmission SS ‘‘B’’ Performance Or Stuck Off
P0758
Transmission SS ‘‘B’’ Electrical Fault
P1106
MAP Circuit Intermittent Voltage High
P1107
MAP Circuit Intermittent Voltage Low
P1108
Barometric Pressure Circuit Input High
P1111
IAT Sensor Circuit Intermittent Voltage High
P1112
IAT Sensor Circuit Intermittent Voltage Low
P1114
ECT Sensor Circuit Intermittent Voltage Low
P1115
ECT Sensor Circuit Intermittent Voltage High
P1121
TP Sensor Circuit Intermittent Voltage High
P1122
TP Sensor Circuit Intermittent Voltage Low
P1133
H02S Insufficient Switching Bank 1 Sensor 1
P1134
H02S Transition Time Ratio Bank 1 Sensor 1
P1153
H02S Insufficient Switching Bank 2 Sensor 1
P1154
H02S Transition Time Ratio Bank 2 Sensor 1
P1171
Fuel System Lean During Acceleration
P1297
Electrical Load Detector Circuit Input Low
P1298
Electrical Load Detector Circuit Input High
P1300
Random Misfire
P1336
CKP System Variation Not Learned
P1359
CKP/TDC Sensor Disconnected
P1361
TDC Sensor Intermittent Interruption
P1362
TDC Sensor No Signal
P1380
ABS Rough Road System Fault
P1381
Cylinder Position Sensor Intermittent Interruption, Misfire Detected (Except 1998 Rodeo)
ABS Rough Road Class 2 Serial Data Fault Or Link Error (1998 Rodeo)
P1382
Cylinder Position Sensor No Signal
P1390
G Sensor Circuit Intermittent Voltage Low
P1391
G Sensor Performance
P1392
G Sensor Voltage Low
P1393
G Sensor Voltage High
P1394
G Sensor Intermittent Voltage High
P1404
EGR Valve Stuck Closed
P1406
EGR Valve Pintle Position Circuit
P1441
EVAP System Flow During Non-Purge
P1442
EVAP Vacuum Switch Voltage High During Ignition On
P1459
EVAP Emission Purge Flow Switch Malfunction
P1491
EGR Valve Lift Insufficient Detected
P1498
EGR Valve Lift Sensor Voltage High
P1508
IAC System RPM Low
P1509
IAC System RPM High
P1546
A/C Compressor Clutch Output Circuit Malfunction
P1548
P1607
PCM Internal Circuit Failure ‘‘A’’
P1618
SPI Communications Error
P1625
PCM Unexpected Reset
P1627
PCM A/D Conversion Malfunction
P1635
5 Volt Reference Voltage Circuit Malfunction
P1640
ODM 1 Input Voltage High (Except 1998 Rodeo)
ODM Output ‘‘A’’ Circuit Fault (1998 Rodeo)
P1650
Quad Driver Module ‘‘A’’ Fault
P1790
Trans ROM Checksum Error
P1792
Trans EEPROM Checksum Error
P1835
Trans Kickdown Switch Malfunction
P1850
Brake Band Apply Solenoid Malfunction
P1860
TCC PWM Solenoid Circuit Failure
P1870
Transmission Component Slipping
