Headlilght design - Same for 96 & 95 Legacy Wagon?
Hi all - just purchased a '96 Subaru Legacy Wagon, the basic model - 196+K miles - hey, I know, and, for $1100, that's ok... it runs smoothly, and seems to have a brake issue on the front, esp when braking from higher speeds... rotors? it stops fine, just seems to vibrate a bit... odd..
the left headlight cover [plastic] is broken and the price of a new one is ridiculous, so, here's my question - my local Pull-a-Part has a '95 Legacy - will the headlight assembly fit my '96 Legacy wagon?
thanks!
thanks!
The vibrating is likely to be slightly warped rotor(s).
thanks again!
The deterioration of the joint is usually caused by a CV joint boot cracking and releasing the grease held within. You should be able to look under the car, near the wheel on the offending side, and see clearly whether or not the boot is cracked. If it is, there is your culprit, without a doubt.
