Isuzu Rodeo 4x4 questions
I have a 1994 Rodeo LS and have a few questions.
First : Does this model have an indicator light on the dash that tells you if the 4x4 is on ?
Second : What is the correct way for this model to change from 2 wheel drive to 4x4 ?
I can only seem to move the 4x4 stick when the engine is off.
Thanks in advance for the input.
Rob
Rob
2nd, DO NOT let the dealer sell you a new engine wiring harness for $800!
I have a 2000 Rodeo S 4X4 and had the same exact problem. If I remember correctly, the radio and windshield wipers and maybe defrost also went out.
Do you have a wire plug for trailer lights on the back of your car? If so unplug it, You can find the connection on the drivers side in the back side compartment where the jack is stored, stick your hand & arm in the space behind the jack, like you reaching up towards the rear side window, you will feel some wires going to the tail lights and the wire for the trailer will "T" into the main wire, it is pluged in so pulling it apart will work, try to support the other wires before you just start pulling it!
Problem #2
Does your Rodeo go into 4wd by it self or especially when someone is sitting in the front passenger seat, if so let me know and I'll tell you how to fix that too.
RodeoGuy
Just as a background, I had the tranny rebuilt last year and computer replaced with another used one. It seams like the computer messed up the tranny. Thanks for any feedback.
Brandonius
I put it in shop they broke clutch release bearing assembly ( I'm not sure if is called that) but the bearing is pressed on this part and it attaches to clutch fork with a spring.
My truck has been down for for bout 14 months I can not find part I've called Isuzu they discontinued I've tried pick parts .
Please help
But the 23 days they had it. They dropped tranny 5 times. They couldn't get new clutch to work. Long story.of course I told them truck was MUA required high performance clutch .
They tried 5 different clutchkits. Come to find out after I demanded old parts to be put back in and return truck .
They came gave me new clutch kit I paid 300 already . But When I returned it . I have
It was the 89.00 14 tooth not 245.00 24 tooth
Is that possible for they to install at all a 14 tooth kit on my 24 tooth trans
I have a 1998 isuzu rodeo and the 4wd doesn't work when I push the button the green light on the dash just blinks and I hear something engaging in the transmission and it will go from 4hi to 4low but for some reason the front wheels won't engage.
Any ideas and thank you for any help you can offer.
