Isuzu Rodeo Has No Power to Fuel Pump and Injectors
all relays and fuses are good, jumped f-pump to test & fuel flows to t-body with good pressure but still will not start because injectors are not doing what ever, starts when priming t-body for a few seconds till fuel is exhausted, replaced oil sending unit, some one said it sends a sig. to ecm which has been opened and seems to have no visible damage,
just about have it, now its starting and runs for about 5 seconds until blowing fuse
# 8, labeled "Engine Back. L" (10amp)
Any ideals
my problem was electrical, removing the batt (neg. terminal) for a few seconds resets the Engine Control Module (ECM) which operates the full pump relay, there should be a fuse in the relay box in under the hood labeled ECM or ECU. Pulling that fuse for 10 secs. or so also resets the ECM, try this and if it immediately works I suggest to drive it locally until it will not start again and repeat the removal of the ECM fuse. If this work out I suggest that you ECM is receiving a sensor signal to shut down the pump relay so I've been told, is the check engine lite on ??????
