thanks for any information.
I'm considering a lease on a 2010 Venza vs. a Subaru Outback.
All the toyota safety recalls has me very concerned.
Should I cross Toyota off my short list?
Would you buy a Venza today?
Mike
My 2009 Venza has about 19,000 miles and I have had ZERO mechanical problems. I recently completed a 600 mile round trip to St. Louis and got 30.4 mpg! This was with a load of 3 adults, one baby, one golden retriever and luggage and averaging 70 mph. I heartedly recommend the Venza as a replacement for you Freestyle.
could we assume that a new venza has been corrected for all the issues that came up until now? any preference between 4 cyl and 6 cyl from the performance point of view?
That remains to be seen. It is entirely possible that the DBW throttle control firmware is responsible for the three apparently VALID engine runaway incidents.
"Venzas did not have this problem.."
Says who..? By what authority do you make this statement..?
" doing a computer update.."
Useless, quite possibly USELESS computer update.
Suppose, like I suspect, it actually is the engine/transaxle (DBW, CC) firmware that is flawed...? Embed another firmware routine to "signal" the DBW firmware routine to drive the throttle plate closed.
That's a false sense of security, safety, if I ever heard one.
A true failsafe for an inadvertent WOT condition would/SHOULD be implemented entirely separate from any possible causative factors/components. A simple relay system that opened the fuel injector circuit should the throttle plate not quickly return to idle upon brake application would be satisfactory IMMHO.
On the other hand I would also likely drop a front halfshaft and apply a constant 12 volts to the rear drive engagement clutch,....a safe, MORE SAFE, RWD Venza. There is an aftermarket device available so the front halfshaft could be manually (dis,) engaged.
But what I would REALLY jump at purchasing would be a F/awd Venza using the I4 but upgraded to/with DFI. Improved FE and HP/torque, 187HP now to 210-225(??). Or the displacement of the I4 could be lowered keeping the 187HP level but with absolutely STELLAR FE.
No gas pedal issues, yet at the 5,000 mile check up they worked on the pedal and reprogramed the throttle computer. The main issue was communication - We never got a recall notice for the work that was done and the dealership we bought it from said there was no throttle issue with the Venza.
So how many other brands have had recalls without the Toyota notoriaty? We believe Toyota is in the spot light and things appear worse than they are. Like asking when did you stop beating your wife - same as asking when Toyota stopped building cars with safety issues. We believe they nare still a quality vehicle.
