Help! CR-V loud popping from wheel after stuck in snow
in Honda
I live in virginia and we just got a big snow, last night I was parking at my mother's and tried to park in an open spot (about 12 inches unpacked undisturbed snow) the frame was dragging. I had no problems in forward at first when I put it in reverse something happened and it now pops once or twice for every wheel rotation on th right rear wheel, mostly in forward not so much in reverse now that the problem has matured 15 or so miles. the awd still works. my v is a 2005 ex with about 77k gets fair amount of off road driving(nothing extreme just commuting to hunt camp on packed dirt trails) It is not the diff fluid as I experienced this problem when I bought it and fixed it. this noise sounds very severe and I don't want to drive it if I don't have to until I can get it looked at. Anyone know what might cause this and could it be a simple fix? thanks for any help!
See if that solves the problem.
Does tha year have VSA? I wonder if the speed sensor or something related to it was damaged and its' triggering the ABS to slow that one wheel occasionally. Although I'd expect a ABS trouble light to come on in that case.
As for the TPMS light always being on - this typically means one or more of your 5 tires (including the spare) have less than 27 lbs of air pressure in them. Take your CRV to a gas station and fill each of the 5 tires to 30 psi air pressure. The TPMS light should now go off. If it later comes back on, you k now you have a leak in a tire. Find the one with 27 psi airpressure and have it repaired. However, if once you fill your tires to 30 psi the TPMS light stays on, then you have a bad TPMS sensor on one of the tires. Your mechanic can determine which one and replace it.
