2010 Pilot Noisy Shift Lever
yogi1956yogi1956 Member Posts: 3
edited August 2014 in Honda
Hi
We have a 2010 Pilot Tour 4WD. After 500 miles the multi piece plastic housing around the shift lever has started squeeking from the pieces rubbing together, It is getting more frequent and louder. Anyone know of a TSB or fix? We haven't been in for our first service visit yet but sometimes it helps if someone else has had the same issue resolved.
Thanks, George
  • fritz98fritz98 Member Posts: 2
    George,
    Did you ever get resolution on this? This is starting to happen on my 2011.
    - Fritz
    "Hi
    Thanks, George "
  • yogi1956yogi1956 Member Posts: 3
    It stopped on it's own after I sprayed wd40 and banged on it a bit. Now my driver seat shudders when going back but the dealer says Honda doesn't consider this a problem. I'm not impressed with this SUV. We've had several Hondas and this will be our last
