BMW 5 Series - Battery Problem
I bought my BMW 520 (first registration Sep 01) in Nov 2008. In Jan 09, the battery was going flat often. Since then, the battery has been changed 4 times, alternator changed twice and an electrician has checked the drainage system but i tried starting the car yesterday after a new battery was fitted on Thursday 31st Dec 09 and it was flat. I dont know what to do now. Help.
I'm experiencing the problem that you've discussed. I bought my 530 BMW (2004, premodel) several years ago, and have experienced my fan turning on during random times as I drive. I noticed a lagg when I turn the ignition, and then in October of last year, my car battery just died. I took my car into a shop that works on only BMWs. After doing some research, I learned that the final stage unit can cause the climate control to act improperly. So when the shop told me the problem was my battery, I questioned them. They said that the problem did not act up when they had my car, and they did not find a draw. I bought a brand new battery from them and went on my way.
However, when I took it home, I noticed that the fan did not turn on when I drove it, but instead the fan turned on when the car went to sleep mode. So when I started the car, the fan would be running. I took it back to the shop, they checked it again, and they said that it was blower motor resistor. I was upset that they didn't diagnosis it before and had me buy a battery. I wanted to get a second opinion, and took my car to the BMW dealer. I told the dealer my problem and the technician said it's probably the blower motor. But after they looked at it overnight, the service writer said that they found no draw. This is quiet perculiar to me because my battery keeps on dying. The dealer said that I needed to buy a brand new BMW battery....I told them there is no such thing and there are only a few battery manufactures that everyone buys from.
So my car is still not fixed, and my brand new battery is completely dead and has to be jumped. I'm waiting for the new BMW recall list this month hoping the final stage will be on there. Do you know why I'm getting the run around from these companies? It's ridiculous how my problem points to the final stage unit, and the dealer is trying to sell me a battery I don't need. Any advice on what I can do?
If it's an E39, replace the FSU yourself.
Anyone with any experience with such a charger?
I have been looking into solar trickle chargers but I'm not sure if it will solve your battery problem. I'm still trying to find a cheap resolution to keep my battery from draining. However, according the BMW service center rep, I have to drive my car 45 miles A DAY to maintain the battery charge. That's ridiculous.
So far, I have good luck driving my car once every two weeks for a 1/2 hour. 50% of the time i have to redo the clock and date (which I should not have to do).
Anyway, my point is I know exactly what you are going through and been told a solar trickle/maintainer might help.
Any courtesy lamp that doesn't turn off (trunk, glove box, footwell, engine bay, lighter, etc. can, over time, draw a battery down.
I contacted Schumacher, who makes several models of trickle chargers, and they recommended one that they make for Sears. I purchased this unit ($30.00), and it is basically fool proof. Of course, how long it will last is another question.
Thanks again for your input.
I've read through most of the thread on your electrical problem but one thing is not clear to me.
Are you talking about the interior ventilation fan or the engine cooling fans?
To the point, the engine cooling fans are thermostat activated and will run if the sensors say the motor/water temperature is to high.
Many good ideas posted here but one that no one touched on.
The interior lights are activated by a switch on each door. Many years ago this was
a small button style switch located near the door hinges. In Particular BMW has gone to a "Door guide switch" to activate the interior lights. I'm speaking about that black & aluminum bracket located on the C Post between the front & rear doors.
Check those to insure the switch portion is working correctly.
There is also a gas cap door switch which I believe is electrical, make sure that's in working order. You may have to pull the trunk side panel out to get to the switch
and related wires.
One last area! I had a 1990 BMW 5 series and found a bunch of electrical relays located under the rear seat bottom. Good place to look and check for loose connections.
Battery trickle chargers are great little device. I'm not sure why I should have to buy one of those for an automobile, made in Germany, that cost $40K or more, but that's me.
Good luck with those electrical Gremlins.
Best Regards :shades:
JKAudiA6
I have a 2006 530 wagon (with 46,000miles) that has the same exact problem. Brought it to Dinan and the tech is still trying to figure out the extend of the damage and the cause of it all. So far, he's found 5 panels in the trunk area all rusted and corroded, an puddles of water under the spare tire and battery. He need to first replace these to check further since the computer is not communicated all the way through for fault codes. My I-drive is also dead. Unfortunately the warrenty expired 11/09. The dealer tells me it's not a common problem at all (of course not). Is your problem fixed? What was the cause and cost for repair? Thx much!
tkx, Mike
Here's the text:
Battery maintenance requirements from the Owner’s handbook
Battery Care
If your car is driven only for short distances of less than 10 miles over a prolonged period of time, without an occasional drive at highway speeds, the engines charging system will not properly maintain the battery.
Insufficient use of the vehicle could result in short term starting problems and in the long term could damage the battery.
In case the car is not operated for several weeks it is advisable to:
A. Consider using a proper trickle charger, following the charger manufacturer’s
instructions, to maintain the battery’s state of charge.
Advanced Battery Charging System with Alligator Clips
This Advanced Battery Charging System can help you extend the life of your battery. Simply plug the 1.25-amp charger into
a standard 115-VAC wall outlet and connect the alligator clips to your terminals under the hood. The device's on-board
microchip monitors and regulates the charge- virtually eliminating sulfating. It can even help extend the life of your battery.
(PN: 82 11 0 406 881)
B. Consult your BMW center regarding battery removal.
Once removed, the battery must be charged and stored in a cool, dry place where it can be protected
from freezing.
If the battery will be stored for over 3 months, it must be recharged every 3 months, or else it will become
damaged and useless.
What part is most likely affected by this, assuming located in the trunk, and how the water got in there?
Any ideas would be appreciated.
Do you know by any chance what electrical components were replaced in your car ? There are several in the trunk, stereo equipment is there also, amplifier etc...
If you still have the paperwork from the repair, maybe they listed the panels they replaced.
Thank you very much for any help you have.
BMW technicians only say that I need to drive the car more. Well, I drive it every day about 20 miles. How much more I need to drive? They won't specify that. How ridiculous is it to drive around the town aimlessly just because one owns a BMW!! They should add this as part of their wonderful ownership experience.
I called BMW customer relations, and I was rater hastily told that the owner's manual had battery maintenance instructions, and it was my problem that the car was experiencing electrical problem. (I checked the owners manual, it had nothing that stated anything that applied to my problem whatsoever. It stated "if the car is not driven for 4 weeks....". But, I drive it every day!) I am sure they train their customer relations reps to say that because they know about the issue, and are unwilling to fix it, and are just trying to avoid a recall.
I am done owning BMWs. They make overpriced pieces of junks.
I don't think there is a new BMW in my future either!!
No battery likes to be deep discharged and will be degraded each time it needs a jump start.
For a vehicle that is not driven much, or, has lots of short trips especially in cold weather that taxes the battery even more, it's a good idea to purchase and USE a trickle charger. This is becoming true of ANY new, complex, modern car; not just BMW. The more do-dads there are, the bigger the problem. Think about it; stuff like the remote receiver needs to be on all the time so it can respond to you pressing the open button on the fob. Most of these cars have an alarm system with ultrasonic detectors (or maybe radar) that try to keep the vehicle from being stolen, or at least make some noise when it happens, and, a gps system might try to turn on once in awhile so you get a quick position fix when you actually do turn it on.
Now that I'm retired, I may need to take my own advice. I pick up a new GT in a little over a week (well, I drove it in Germany in APril, but it's still new). I've been filling the tank on my current vehicle maybe once a month or two..not many miles.
Remember something: these new vehicles ALL (Audi, Lex, etc) all have sophisticated electronic systems. Even Hyundai now has a push button start for example. I'm use to sitting down at the beach with the car radio on (former 1996 328i) but back then, there were no iDrives. We just have to be aware, these systems draw more current from the batt.
Re Sunroof: i learned the hard way in my 1996 328i, those sunroof carriage assemblies can go bad. Now, I NEVER open the sunroof (why do you need to?) Just use it for the beautiful sunlight coming through, and keep it closed. And you won't have to worry about that problem. Keep it simple guys. Don't blame the vehicle. You think Mercedes is going to be less complex?
I love my car otherwise.
After reading your postings, I'm relieved to know that my suspicions were correct. At least now it will not be my problem and the Dealer will have to figure out and correct the problem if they want to make a profit.
I have a 05, 545i, just replaced the battery a few months ago .... have electrical problem after electrical problem .... sometimes 20 faults per hour!!! Car will roll down windows, engage cruise control, wash windows, change radio stations, even adjust you right into the steering wheel while driving .... no, much more serious than many have posted above.
This month though, the car has decided just not to start. In trying to trace the current problem, I notice that the IBS is burnt out. I saw at least someone else mention this. I've found it for as little as $150 US but would like to know why this happened? I though with a degree in CIS, I might be able to handle these problems ... but it's not quitting anytime soon.
I was thinking of checking the ECM as I here that many of these items send/receive info on a data bus of varying types back & for to the ECM. Any thoughts where to check myself?
Jonathan Burke
i have a 550I and Im having issues with my fan fuse blowing out,would a bad battery also be the problem or a bad blower motor
