Don't Buy a Cobalt
I made that mistake and it has been problems since. Power Steering out at 41,000 and Fuel pump out at 50,000. Piece of junk. The rest of my problems are detailed here:
http://tysonq.wordpress.com/
Sounds like you bought it used. Never know what you'll get if that's the case.
While they had some issues the first 2 years, I've seen very few issues since and yes I work on cars every day and have since the late 60s.
I own a 07 and 09 and am considering a third before they phase it out.
With nearly 40 years in the service bays, I've yet to see any manufacturer not have some issues. Odds are some abuse was in play here too.
A warranty is a contract, nothing more. Most if put in the same position would do the same if asked to warrant something past the contracts terms.
Cobalt #3 is coming to a new home in Feb.
Many times I've had people with issues that didn't fall within the parameters of the contract. If they are nice I've gone out of my way to try and help and in many cases I've had the shop do the work at a discount to cover costs only. Those that are rude get nothing extra.
Bottom line be nice and make sure your documentation is in order. Even if your documentation is in order and the dealer won't help then go to corporate. No response there contact your states AG office and the BBB.
Gl
It was a pre-owned so I got someone else problems. The one I have is a 2009 LT and at time of purchase only had 19700.
By 20000 the steering shaft had snaped, by 20090 a problem with the airbag light, by 20100 relized was only getting 16 MPG. By 20200 had exhaust fumes coming in when I would use heater,by 22240 all lights would turn off and then come back on when ever I would hit a bump in the road.
The car has been back many times and will keep going back until the problem is fixed.
I like the Cobalt very much I just don't like all the problems.
Today it went back once againg for the exhaust fumes and this time another bandage was placed on the problem by drilling holes in the heater and installing deoderizer.
Well if you can not fix the problem cover it up.
Consider a different dealer.
To be clear I don't want to hear my horn unless I press the horn button on the steering wheel.
Possible?
Seriously? The carbon monoxide will kill you.
Does or has any one else experienced these problems?
Previous problems that I have had resolved already:
1.Front passenger window sounded like it was letting air in and made a whistling sound while driving down the road. Well, after going into the shop 3 times the issue was finally fixed.
2.Key kept getting stuck in the ignition. Took it in and they had to replace the gearbox. Took one time to figure out the issue and get it fixed.
Current problems:
1.Info button on steering wheel does not work when my headlights are on.
2.When I am turning the volume up or down on the steering wheel sometimes it will change the radio channel.
3.Unlocks and locks it self while being turned off and parked.
4.At a steady speed driving down the road it while just down shift.
5.Both mirrors on my sun visor the clips broke. I was not over using them either.
6.Transmission jerks when it shifts between 30-55 mph.
7.The clips on my mirrors on sun visor broke. I did not over use them.
8.No for sure, how long this issue has been happening just made aware of it today. When I pulled up to park at work a bunch of employees were setting at the break tables in front of me. I got out of my car and they said, “There is something wrong with your car, when you turn it off it let out a big cloud of smoke!” I was in shock it was not over heating nor is any of my fluids low.
I suppose I need to take it in the shop but it is so frustrating trying to find a vehicle to borrow to drive while mine is in the shop. In addition, they always say uhhh we could not get it to do any of those things. Now after reading all of these posts and doing research this scares me.
I also for got to mention that when I go to take off it is very hesitant and seems like it doesn't want to go or cannot pull its self.
I see.
So they should buy a Corolla with steering problems? Really cheap interior? Odd placement of the steering wheel relative to the seat?
Or should they buy a Civic with the engine block leaks? And other problems known on the various discussion groups for both cars. The regulars respond with "Oh, yeah. That's a known problem"?
It's nice that you love your Honda. All cars have some problems sometimes the owners cause the problems in various ways.
Recalls are not formed based on if they are safety issues. GM monitors the complaints from customers to customer assistance. This is how they discover widespread problems. I am unsure of how common this problem is or what is the cause of it. The service department at your dealer would be a good resource for this information.
Christina
GM Customer Service
