Honda CR-V oil life percentage
bsilverbsilver Member Posts: 1
edited June 2014 in Honda
I own a 2009 CR-V and just had the oil changed. When I checked the oil life sensor it still has the same percentage it had before I changed it. Any ideas?
  • oldcemoldcem Member Posts: 309
    You have to manually reset your oil life indicator. Check your owner's manual - it should tell you how to do it. If it doesn't - get on one of the Honda CRV forums, and, search for the reset procedure.
    Regards:
    OldCEM
