Durango Starting to Burn Fuel lean after replacing O2 sensor
My vehicle starting to burn fuel really rich. Dropped down to 4 mpgs. Vehicle starting smelling alot like gas. Engine light turned on. took it in and the meter stated I had to replace the O2 sensor. I did that. Fuel returned to normal, Now after a week, i am starting to smell the fuel again but the engine light is not on to take a reading. Any ideas on where to check next?
1. If you have had PS fluid run down the wiring harness you may be looking at having to replace it. The fluid get's down there and does some horrible things to the wiring and it's insulation. This has been a problem with a few on other Durango/Dakota boards.
2. Check/change your throttle positioning sensor (TPS). The changes in your idle speed indicates this may be an issue.
