2004 Chevrolet Malibu LT problems - can someone advise?
Hello everyone, was wondering if someone could describe possible reasons for the some of the issues we are having with our Malibu.
a) We can no longer down shift to 2nd or 1st gear. When we go to 3rd gear and press the down shift button on the shifter, nothing happens. Dealer says it will cost $100 / hr for inspection to see what's going on.
b) When we fill up our gas tank, the fuel guage still says empty. Then suddenly after a quarter tank, the fuel guage seems to work fine. Could this be a problem with the sender?
c) When we turn, we constantly get noises from the steering. its like a clunking noise. Dealer claims there is no issue, but when we drive and we make turns, it almost feels the car isn't making a smooth turn.
Any input on these issues would greatly be appreciated.
Our horn doesn't work correctly. When you honk, it's not very clear...it sounds like you are pushing air and you can barely hear the horn...can this be easily replaced or fixed?
gas tank issue...would agree is probably the sending unit
steering clunk....notorious issue with the 04-07 MY cars....poor engineering design, have it inspected by an independent mechanic...check control arms and tire rods. Again an issue that I have lived with..and 158K on the car with no ill effects
horn...no clue
also check the tire rods...on both sides...inner and upper...to see if they are worn/loose....insure the tires are properly balanced and probably not a bad idea to have a front end alignment check..
same model here with 168K on it...and still going strong...
I upgraded to 17 inch aftermarket rims....and running 225/45/17 tires....just replace the BFGs Sport A/S which I got 35K out of with Goodyear Eagle GTs with a 50K warranty....best set was Michelin but didnt want to spend $200 a tire this time......the Goodyears were $135.....
I have read on many car forums that this is a widespread, well known and documented issue and that GM does not take responsibility for it. I have seen hundreds and hundreds of complaints on the NHTSB forums and cannot figure out why this issue has not been reinvestigated. Apparently it was checked into in 2004 or so but was closed with no recall ordered. I get NOWHERE with GM, or the NHTSB. Guess my next course of action is with the Federal trade commission. I am tired of GM pretending that there is no issue with the steering in the 2004 Malibu's. I would love to see a class action lawsuit get started on this as I can't seem to get GM to respond to my safety concerns. I am afraid to drive my car and don't want to pay to have it fixed as it appears that this issue is ongoing even after repair. Stay Away from GM cars- The customer service/complaint dept is aware of the numerous complaints but does absolutely nothing. Does anyone know of a class action lawsuit that is in process for this yet? If not we need to unite and start one before someone gets killed-
is "like Maxx", it's not a 2004 classic. Present your facts straight,
please, if you want to be believed.
It seems that a recall was done on the Malibu Maxx for this same exact issue, but not for the Malibu classic model that I have- makes no sense at all-
Can't find much sense in your manifesto.
It is a huge safety issue- If you value your life, do not buy GM- they do not back their products at all-
Nonsense -- who are you to make this blanket statement?
Pay to have it fixed if you are afraid to drive it -- there can be no other sane opinion.
Sure.
there is a power steering issue documented in the 04 MY new design malibus...and GM in most cases has made repairs under warranty and in some cases has even issued extended warranties for this particular issue
NHTSA did investigate this issue....an engineering design study is what I believe it was called...and looking at the percentage of complaints vice total production....it was determined GM was handling the issue properly under warranty repairs...if you go to the actual NTSB website....there arent hundreds and hundreds of complaints as you describe....perhaps there are on numerous internet forum sites.....but not officially documented at the gov website....
How many times have you had this problem documented with the dealer? How many times have you attempted to repair the problem?....you leave many facts out of your broad brush statement....and yes..I own two other GM cars other than my Maxx
