2005 Sienna ventilation never off
This may have been asked and answered, here, but I'm never sure what, exactly, to search for.
I bought a used 2005 Sienna XLE in October 2009. Is it normal that, even when my heat/ac fan is "off," it still blows air? If it was last set warm, it blows warm. If it was last set cool, it blows cool. But it's never OFF, completely. It only blows slightly, even if I last had it set high, so I'm getting the impression that Toyota assumed you'd never want it completely off (a dumb assumption, if they did) - but I *do* want it off. Am I missing some mystery control that shuts this all the way off?
But there are two workarounds.
Put the system in recirculate - NEVER to be done in cold climates
Put the system in defrost/defog/demist. Does not shut off natural airflow due to forward vehicle motion but somewhat "baffles" it by forcing 180 degree reversal in flow direction.
In over 50 years of driving I don't think I have EVER encountered one of those.
Define "cold," (North Georgia in January?) and why, please? What's the relationship between recirculate and cold air?
Cool or cold climate = cool or cold interior windshield surfaces = fogging.
Regretably this all relates to dewpoint and mother nature is mostly in charge of that parameter. So it's a good idea to NEVER use recirculate when the primary HVAC mode is for heating, keeping the passenger cabin warmed.
The new 2010 RX350's automatic climate control will not only prevent you from using recirculate "improperly" but will automatically switch the system into combined floor/windshield air outflow depending on outside climatic conditions. That will tend to keep the interior surface of the windshield warmed above dewpoint even with COLD airflow impinging on the exterior surface.
And...
A manual HVAC that has a servomotor that automatically closes the fresh air inflow path when the blower is turned off.
"Does NOT compute..!!""
"..would shutoff the outside air damper.."
The MANUAL system outside air damper, typically, has two positions, FRESH and RECIRCULATE. It might automatically move from recirculate to fresh if the blower is turned off, and more likely so, MUCH more likely so if the A/C is turned off. But it would be patently UNSAFE for it to completely close off the incoming fresh air flow.
I would more readily believe "..damper goes to fresh..".
Cars do not need to be very airtight for rising cabin humidity to be a problem during coolish or cold climate(***) operations. So the default damper position should ALWAYS be FRESH.
*** Climatic periods, basically, when the only usefulness for the A/C is for dehumification.
