Sprinter motor home chassis
I am looking to buy a Winnebago View series 24' motor home on a V-6 Sprinter Chassis. I would like to hear commenst both good and bad about this choice. It has a 5K tow rating and I will be owing a 3,000 pound Honda.
Any info would be appreciated.
JLO
Lee Parmeter Biloxi, Ms
I have heard of some Rv manufactures having problems with the way they mounted their coach on the Sprinter chassis. Mine is a Winnebago Navion and no problems there either. Lee Parmeter Biloxi, Ms
thank you,
jlo
I have had no trouble getting low sulpher diesel except on remote back roads. Below is the phase in list. Lee Parmeter
Effective Dates for Highway ULSD Fuel Who
What U.S. California
Refiners &
Importers Import/produce at least 80% ULSD for on highway use 6/01/06
Import/produce at least 100% ULSD for on highway use 6/01/10 6/01/06
Downstream from
Refineries through
Fuel Terminals Facilities that choose to carry ULSD must meet 15 ppm
sulfur specification 9/01/06
All highway diesel must be ULSD 10/01/10 7/15/06
Retail Outlets Facilities that choose to carry ULSD must meet
15 ppm sulfur specification 10/15/06
All highway diesel must be ULSD 12/01/10 9/01/06
Although ULSD fuel is the dominant highway diesel fuel produced, EPA does not require service stations and truck stops to sell ULSD fuel. Therefore, ULSD fuel might not be available at every service station or truck stop. Diesel retailers may choose to sell Low Sulfur Diesel fuel instead of ULSD fuel until December 1, 2010, when only ULSD fuel will be available for highway use. The industries involved in the transition are doing all they can to minimize potential inconveniences during the conversion to ULSD fuel.
Click here for Downlodable Pump Labels in TIF, JPG, and EPS formats
Federal regulations require the labeling of diesel fuel pumps to specify the type of fuel dispensed by each pump (except in California where all diesel fuel must be ULSD). Similar vehicle instrument panel and fuel inlet/fill cap labeling is mandated for 2007 and later model year highway engines and vehicles that require ULSD fuel.* Consumers are advised to check the pump and
vehicle labels to ensure they are refueling with the proper diesel fuel consistent with their
vehicle warranties.
Data from EPA's ULSD pump survey from the Fourth Quarter of 2006 through the Second Quarter of 2010 indicate that more than 99 percent of highway diesel fuel pumps are now dispensing Ultra Low Sulfur Diesel (ULSD).
The EPA standards provide strong incentives for suppliers to provide the proper ULSD fuel formulation. Civil penalties of up to $32,500 per violation per day can be assessed for non-compliance with EPA’s ULSD fuel standards, or for misrepresentation of the sulfur level of
diesel fuel.
Click here for EPA Winterization Standards Letter 11-30-07 (PDF).
Guidance for Underground Storage Tank Management at ULSD Dispensing Facilities 8-16-10
*Exception – Some 2007 model year medium-duty and heavy-duty trucks may be equipped with 2006 engines and emission systems. These vehicles are not required to use ULSD fuel.
