Mazda CX-9 Dead Battery
                    New 2010 CX-9 bought on Dec 18. Love it so far. Came across a strange issue yesterday. We are in Northern New Jersey where it has been very cold lately. Yesterday, the car was not used so it was outside the entire day. Late  evening (7pm or so) I found that the battery was dead, doors wouldn't open.
I slapped my head thinking that I must have left the interior dome lights on, the most common reason for this. But to my surprise, that wasn't the case. One thing I did notice is that the front passenger seat seemed a little warm to the touch in spite of the seat warmer being off. But then again this shouldn't be drawing battery power when the ignition is switched off. I couldn't see anything that might have used up the battery. I jump started it and it is fine but this is a little disturbing for a new car.
Anyone else with a similar experience?
Many 2010 CX9s have this issue (due to the new two-settings warmer). The seat warmer is draining battery even though it is off. Find the fuse for it and pull it out. Call the dealer. They should have the fix already in house for that.
It will happen again if you don't take action.
2009 and prior models have no such issue.
Also, can I pull the fuse out myself, how would I do that?
2010 Seat Heater Recall
Vehicle Make / Model: Model Year(s):
MAZDA / CX-9 2010
Manufacturer: MAZDA MOTOR CORP Mfr’s Report Date: FEB 19, 2010
NHTSA CAMPAIGN ID Number: 10V051000 N/A NHTSA Action Number: N/A
Component: SEATS:FRONT ASSEMBLY:SEAT HEATER/COOLER
Potential Number of Units Affected: 12300
Summary: MAZDA IS RECALLING CERTAIN MODEL YEAR 2010 CX-9 VEHICLES EQUIPPED WITH ELECTRICALLY HEATED FRONT SEATS. THERE IS A POSSIBILITY UNDER EXTREMELY COLD CONDITIONS FOR THE SEAT HEATER CONTROL CIRCUIT TO OVERHEAT AND FAIL DUE TO INSUFFICIENT ELECTRICAL GROUNDING.
Consequence: THIS MAY CAUSE BURN DAMAGE OF THE SEAT CUSHION SURFACE, OR A RISK OF SMOKE/FIRE.
Remedy: DEALERS WILL INSTALL AN ADDITIONAL GROUND HARNESS ON THE SEAT HEATER CONTROL SYSTEM. THE SEAT HEATER CONTROL CIRCUIT WILL BE REPLACED IF NECESSARY AND/OR THE SEAT WILL BE REPAIRED FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN ON OR BEFORE MARCH 9, 2010. OWNERS MAY CONTACT MAZDA AT 1-800-222-5500.
Notes: MAZDA RECALL NO. 5810B. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Same exact problem. I took in to Mazda Dealer. They said their is an issue with some electronic gizmo that is supposed to turn off electricity to heated seats. Guess what--it does NOT. EVEN when the car ignition is in the OFF position. They even had the main Mazda trouble shooter in Northern NJ stop by and check car and he confirmed. They disabled heated seats, ordered new gizmo (took 2 weeks to get in), replaced gizmo and now all fixed. YOU need to bring your car to dealer immediately.
I thought the battery is rated at least 10AH so just 3 hours of 2 devices drawing around 0.7A (output of charger) wouldn't make it unstart-able.
Any ideas? Thanks
