2003 Subaru Forester moonroof leak
I left work yesterday and found that the drivers seat of my 03 Forester was soaked with water. My first thought (well, my second thought after "It feels cold, so I can't be peeing my pants") was that I had a window leak -- but the armrest and the rest of the door were dry.
Next suspect: Moonroof. Sure enough, the headliner trim at the front left corner of the moonroof was wet. Oh, no, I'm going to have to replace the moonroof.
But after I got home, I googled around and found that moonroofs aren't designed to be waterproof from the outside. There's a little gutter system that drains water down and sends it out the wheel wells.
It was about 30 degrees here in Mpls/St. Paul yesterday afternoon, so I suspect what happened is the little bit of snow on top of my Forester melted, but then somewhere in the drain tube it froze up, blocking it.
So this morning I went out, opened the moonroof and poured hot water down the gutter drains. They seem to be flowing freely now.
Is it safe to assume "problem solved"? I've had my Forester for nearly 7 years and this is the first time this has happened.
Now I just need to throw a Hefty bag on the driver's seat and drive around for about four hours with the defroster on "high" until my seat dries out!
Any thoughts/experiences appreciated.
I'd add a box of baking soda to the interior to absorb any odors. And run the heater to dry it out.
kathy
Kathy
That is a good explanation. It took a long slow supply of water from the roof, that had time to seep past the glass edge, and would then freeze as it trickled down the frigid drain tube.
