2003 GMC HD 6.0 - Computer settings improve mileage
I just bought an 03 1500 GMC HD with the 6.0l. With 152000 miles, I’m concerned with the 13.2 MPG I’m getting. I was expecting to see 16+ as long as you’re not pulling and keep my foot out of it. What I’d like to know is, I’m going to change the plugs
should I go ahead and change the coils also? I’d like to buy a computer chip but this truck to check setting but I’m not sure what to look for out in the market.
Thanks for your input.
Chris Brooks – newbee.
The 1500HD is the equivalent of the 2500LD which is a 3/4 ton truck. GM had some frame issues back in 2003 where they couldn't make a crew cab off of the 1/2 ton frame dut to cab flex so used as a temporary fix, the 2500LD. Because the gross weight is over 8500 pounds your truck doesn't have an EPA rating.
I appreciate the input.
I need some help with a problem I have had for a few months now. I have a 2003 GMC Sierra 1500hd 6.0L pick up with 86,000 miles and it will not start the first turn over. If I then proceed to try again it will start either the second or the third time. If I have driven it recently it usually starts up the first time. I replaced the fuel pressure regulator and that did not help the problem. I noticed if I turn the key from the on and off position quickly 5 or so times, it starts right away. It seems I am not getting the fuel into the motor right away, is this the fuel pump? Fuel filter?
Help me please. CAH
Read more: http://forums.motortrend.com/70/8435044/pickups-suvs/2010-gmc-sierra-1500-pickup- /index.html#ixzz1401Tkoaw
Jill
