2010 sonata jackrabbit starts
Greetings Sonata owners,Bought a new 2010 Sonata 2.4. Everytime I would start from a stand still the vehicle seems to take off so abruptly. I thought the accelerator linkage might need to be adjusted but found out from another forum the gas pedal is "drive by wire" which I think means it is computer controlled ,not mechanical linkage like the old days.I really like the car ,its tight good looking and seems like a winner but I wonder if anyone else has this problem,vince17
to mine, a little driving time and my wifes eyes when she got pinned to the
seat. Our other car is also a V-6 but takes more pedal to the metal. By the way
when my wife got behind the wheel and took off she said, Ow s--t, all I did was
laugh! LOL
Hope this helps. Write EVERYTHING down, note all stalling, don't give up, keep going back. Also I had the accelerator module replaced at 7000, didn't change anything.
I did not understand the problems you mentioned, but I want to share an issue with my Hyundai Sonata 2010 automatic 4 cylinder 175 hp. I got it last feb so its been one year. I didn't drive it much at all (around 7,000 km) and when i did i was really happy with it- i felt smooth and on highways i felt like cruising (i dont speed much anyway).
Recently, i went to my first long trip with the car- the trip was about 1500km. In that trip i noticed that the car isnt that smooth. specially it felt like the engine was having a hard time accelerating. and the acceleration was not smooth at all. usually it was very quick and smooth from stop position, but during the trip i felt it dragging to move from stop. once it finally picked up speed, i also felt the engine was not performing well. on the highway i drove at 120km/hr with around rpm of over 2k. the mielage was over the estimation. 7.8 litres/100km on highway (hyundai says its 7 litres/100km.
i havent driven it much since the trip so cant really say is the reduced performance permanent. should i be worried ? do you think it could be bad quality of gas?
i dont have that much prior driving experience so can't compare with other vehicles i drove.
many thanks for replying
Yes I am in Canada and the driving conditions were really typical on a canadian winter in one of the trips (very windy and cold). My tire pressure etc should be OK as I just had a oil change from the local hyundai dealer.
I am not too worried about the fuel consumption. I know very few can beat Sonata in that class.
My bigger worry is the acceleration/smoothness issue as it affects driving experience so much. I hope the reluctant acceleration goes away soon, as you suggested it will.
yes, i think its exactly the same issue- i just stated my problem in a very "non-technical" way. acceleration was not smooth at all... and at around 40-50km/hour, i feel car not responding at all if i press the accelerator. so im having to press down on the accelerator or keeping the same speed for long time before accelerating.
ill take it to the dealer and try to explain the problem. hopefully the reproramming will improve the situation. i really like the car otherwise..so lets see..
