And, as I pointed out, the *real* problem is the drive-by-wire system itself and reliance on computers instead of a simple cable. As more and more auto makers jump on the video game car bandwagon, expect to see problems every few years.
Absent DBW we woudln't have FWD vehicles with more than ~200HP...!!
DBW allows high HP FWD engines to be detuned during low speed acceleration for safe reasons, let alone total detrottling for TC/VSC without damaging the catalyst.
Let's go FORWARD...
Not by Edmunds, just by the circumstances.
As for the other comment, my dad's Park Avenue has ~240HP, FWD, a throttle cable, and it drives actually pretty slow and old-man like. You really don't need an electronic throttle except for maybe professional racing.
I repeat:
There is no reason why drivers are misapplying pedals in so many different models of Toyotas, but not in many other brands such as GM's that have had very very low numbers of cases per vehicle sold. I would bet there still is an electronics / computer error.
Brake pedal override will help overcome glitches.
I believe they were putting in brake override for free even on NOT recalled models. Ask your Toyota service rep.
Just a firmware change (reflash/update) in the engine/transaxle controlling ECU, an ECU that is already suspect for being the base cause of SUA isn't very creative and may well prove to be absolutely WORTHLESS.
It's just plain smart to rely on low tech solutions whenever you can if it's safety-related. Sometimes a simple hammer is the best solution to your problem, as it were.
What happens if there is a voltage spike and the computers in a car lock up? Or there's a short and something fries itself? Relying on software when mechanical devices work just as well is silly. And yes, that plant should have a *few* manual overrides. I can't imagine a coolant system without a few manual valves in strategic places.
In a dirve by wire car, there's no backup. And no redundant system, sensors, or a second main computer. Nada. Stuff that breaks simply stops working. And if that's your throttle, steering, or brakes, well, have fun with that.
2013 LX 570 2016 LS 460
And the million bucks was spent by Fisher, not the taxpayers. We paid $2.95 each for the pens that went on Apollo VII. The Russians switched to Fisher pens too.
You can buy your own for $50. Cheaper than a Mont Blanc.
Sorry, I don't believe a word they say. Just a liberal guy and his liberal wife putting the liberal spin on everything they can.
CLAIM: Barry and Michelle spent $90,000. on room service at a hotel over the weekend.
FALSE: Actually it was only $87,000.
(btw, you know they're owned by the right wing New York Times, right? :shades: ).
k, back to SUA stuff:
"One of lessons of the Toyota sudden acceleration hysteria should have been that a little data is a dangerous thing. Unfortunately it doesn’t seem that anyone has learned that lesson. Public misconceptions about runaway Toyotas were due in no small part to the NHTSA’s complaint database. Countless media stories were based on a supposed analysis of the complaint database leaving the public with the impression that there was well-documented proof of defects in Toyota vehicles."
Do Complaint Databases Contribute to Safety? (AutoObserver)
“These are the kinds of things you never think to read up on when you’re in a new vehicle or a rental vehicle,” said Henry Jasny, vice president of Advocates for Highway and Auto Safety, which pushed for the standard. “It’s better that it’s standardized.”
Standard Panic Stop for Keyless-Ignition Cars Sought by U.S. (Bloomberg)
Great that these systems have a soft "off" switch, supposing there's even a real off switch, they will however not prevent a real danger and common cause of unintended acceleration, that of driver error.
In the case of some of the new hybrids with E-braking (a spring is used to simulate brake pedal foot [back]pressure) even the brake pedal might prove to be inoperative.
The other option, of course, is to just drive a manual. Clutch in, move to neutral - problem solved, even if the engine is still going crazy.
Many here have said that in Toyota's case, the computer would not let you shift into neutral...so I guess the computer could also stop you from shifting into neutral with a manual.
The darn thing would also probably prevent you from pushing the kill switch.
This whole thing was a tempest in a teapot. Driver error explains everything.
You'll note that not a single case of UA involved a manual transmission vehicle, though there were a few reports of engines racing out of control.
My suggestion was a lever or handle under the dashboard, attached to a rod to a ball-valve in the fuel-line. Normally it is fully open. You need to kill the engine in an emergency you turn the handle 90-degrees. With no new fuel, the engine dies in a few seconds, no ifs ands, or buts.
Sensors and other electronics are convenient, nice, and usually work. When they don't, the average person is going to have a hard time making the right choices.
Does anyone know of a documented situation where someone was prevented from shifting into neutral due to computer malfunction?
The "shifter" does not directly shift gears, it only changes the open/closure of a switch set/group that directs the ECU, computer, as to which gear (or not) you wish to be in.
Beyond that all you need to know is that computers often "crash" or get locked in executing a "deadly embrace.
No computer "monitoring", "polling" those switches, no shift into neutral.
No, the simple, simplest, solution is to have an independent computer, separate control channel, watching the EFI injectors' PWM and the brake light switch. If the EFI's PWM doesn't drop to idle level with the brake light switch "on" then the "separate channel/path" control computer will open (relay) the EFI circuit.
I can give you several instances which happened to me back in the '60's where various MANUAL transmissions got hung up and would not shift at all. Our family had a fairly new International pick-up where gears would hang up. We also had a Nash Rambler that this would happen to. My brother-in-law had one of those small Metropolitans, and the gears would frequently hang up.
All manuals.
Older cars - you're right. As soon as you talk about modern cars, you're talking about systems that are either networked or rely on the same processor boards. In that case it is just like hitting different keys on your keyboard; they should do different things, but they rely on some key component that is down. Or think of an electrical grid; it is not necessary for many individual things to fail, it just requires 1 critical item to fail, and then the rest of the grid is down.
I have a machine here that sorts bottles with 1 subsystem using an optical sensor to detect the open end of the bottle. On the other end of the machine is a subsystem that sorts the up-and-down of a cap by using the weight differential - invoking gravity. The cap subsystem has never failed. The Bottle sorter fails due to dust, misalignment and such. Maybe I'm still influenced by how many times the Robinsons could only stop the Robot by pulling his battery-pack.
It started right up afterwards and drove normally. Turned out it was a bad spring or something like that.
tooth cell phone to call her hub- The car slowed to 35mph. Question not asked
is "What NUMBERS did you dial?" The CRUISE CONTROL light was on, so it was
active. Her RF generator (cell phone) operates at about 14" wave length where any conductor of 7" would be fine tuned to receive that digital signal
Can we say Turn Signal Arm which connects into the Cruise Control. Operating
at 800 MHz, there's no way to get a card in edgewise from continuous signal
If she dialed 35, it wasn't God who intervened, it was her RF Cell Phone- duh
Two hours and 10 minutes into the flight, the computers controlling the flight switched off the autopilot after becoming confused by conflicting speed readings, caused by the icing up of pitot tubes monitoring the plane's velocity.
"There was an inconsistency between the speeds displayed on the left side and the integrated standby instrument system (ISIS). This lasted for less than one minute," the BEA document said.
And:
By the time the Dubois appeared, just over a minute later, and as the plane began its fatal descent, another stall warning had been issued.
With the plane now rocking and falling at 10,000ft a minute, the pilot acknowledged the terrifying speed of the descent, saying "we're going to arrive at level 100", meaning 10,000ft.
At that point, just over a minute before the recordings stopped, the control sticks were used simultaneously, indicating the battle to control the plane had reached a frantic pitch. The pilot handed control to an unnamed colleague, presumed to be Dubois.
By now the "angle of attack", a critical indication of airflow over the wings, was at more than 35 degrees – nearly triple the outer limits for safe flight.
The BEA said the plane remained stalled throughout its three and a half minute descent, with the last recorded measurement showing the plane plummeting at 10,912ft per minute.
http://www.guardian.co.uk/world/2011/may/27/air-france-crash-inquiry
Summary: sensor failure, computer software can not comprehend the error, and professionals looking at the situation can not figure out the cause, system solution or engage a manual operation that is successful.
Everyone on that plane knew they were going down and in serious trouble.
I'm not saying all technology is useless; but there is an infinite number of chaotic events which can cause it to fail. And of course there are the systemic design flaws that all products have - as they are designed by humans.
I've had home computers lock up and "crash" more times than I can count. Not hardly at all on modern (last 7 years) computers, but that's another argument.
I've never, not once, had a computer in an automobile lockup in anyway that impaired any function in my control. It just doesn't happen.
Never had one lock up that impaired function or control? Never had a radio fail? Never had your computerized air conditioning system fail? Never had that rear-window defogger fail? Any one of those is a control system. Maybe not in the same sense as the ECM or BCM, but those, too, fail. I should know--I've had more than one fail in more than one brand of automobile.
Never had a radio fail.
My AC has failed, but it wasn't due to the computer, it was due to the compressor blowing up. It still blew air, but no cold air.
Never had that rear-window defogger fail? Nope. Although the rear windshield washer fluid sprayer has failed, but it is probably either the pump for the rear washer fluid, or most likely, a hole/leak in the tubing to get water all the way to the back from the front that has failed.
EDN (Electronic Design News) Article
NASA Paper
Should have entered my guess in the million dollar contest.
Not to you, anyway. I'll put your vote in with the "pile" of >10,000,000.
