2008 Dakota 4.7 auto Trans leak at tailshaft
                    hello all,
My transmission has started to drip tranny fluid from out of the center of what I want to call the yoke that goes onto the output shaft at the rear of the transmission.
Its not a lot of fluid, its a few drops if it sits overnight parked on an incline with the rear end dowhill.
any idea? Is this a common problem?
Sometimes they seal themselves back up. If it were me, and it's not covered under warranty, I would just keep an eye on the leak and the ATF level, and top off when needed.
Any recent problems with a bad front U-joint, or have you had the driveshaft out of it recently?
Dusty
They said it wasn't a common problem, but they had seen it before in that tranny.
