2000 Oldsmobile Silhouette No Heat and overheats
buckweat54
Member Posts: 2
in Oldsmobile
I have a 2000 Silhouette that the heat went out on and it also started getting coolant in the oil. I figured it had a stuck thermostat and the head gasket was leaking. I went and bought a new Thermostat, Bars Leak Head Gasket repair, and some coolant. I removed the old thermostat and put the housing back on, then I completely flushed the engine, heater core, and radiator. I went through all the steps with the Bars Leak and could actually see it sealing all the leaks on the head gasket. Flushed the system again and put the new thermostat back in and filled the system with new coolant and proceeded to run the car and top off the coolant. Started the vehicle and at first I still had no heat, but about 20 minutes later it started working great. I drove the car for 2 days with no problems. On the third day the heat stopped working and the car started overheating. I can only drive it a couple of miles before it overheats. I haven't had a chance to get in and check the new thermostat, but is there anything else that could be causing this? And how do I fix it? Thanks in advance.
