Isuzu Trooper Alternator Problems
I have a 95 isuzu trooper type s a/t recently my batter went bad and was since replace. however it drained quick and would not hold charge. i replaced the alternator and my lights are still dim and only running at about 11 to 12 volts while idle and driving. we tested the alternator but it is fine at 15 amps. anyone have any ideas what is causing this? please help
I keep going thru alternators. In the last few months, I have gone thru 3 of them. It's really starting to get frustrating. When they start to go bad, I notice a humming squeak like noise. Like the brushes are rubbing inside. Then from there, I notice my truck having more difficulty in starting from the lack of power in my battery. It is obvious that my alternator isn't proving the power to my battery to start like it should. I did replace my battery with a new one, and still the problem persists. One thing I did notice is that it is more relevant in the cold. Also, when my alternator starts to go bad, my headlights, dash lights, any light, starts to randomly dim/increase up and down. I do have fuses attached to everything powered by the battery. So to protect against surges or whatever problem may arise power wise. I am thinking that if there is a short somewhere causing my alternator to go bad, wouldn't a fuse blow?
Anyhow, thank you for taking the time to listen what I have to say. If there is anyone out there who can help me with this, it would be greatly appreciated...
Tracy...
There were a couple things I did forget to mention. When my alternators went bad, I would have them checked at my local auto store for amperage. One thing that was noticeable, is that one alternator had lover voltage compared to the other that had more voltage then the norm. I do disconnect all the wires from my battery before I add leads/grounds to my alternator. I do have a fairly nice stereo with a somewhat high power amp attached to it. Is it possible to add a higher power alternator to my truck?
Tracy
http://www.zena.net/htdocs/alternators/AutoSound2.shtml#Top
Also, a bigger capacity battery might help prevent loading the alternator especially if the load is off more than on, here is a battery that will fit the Trooper battery box and has something like three times the cranking amps and and can be used in deep cycle mode without damage:
http://www.lifelinebatteries.com/marineflyer.php?id=3
Note: Measure your battery box before ordering, I have use the Lifeline battery and an inverter to let my kids watch two movies and then the news while powering a fish aquarium every night for a week after a big ice storm.
-mike
-mike
SUVs and Smart Shopper
-mike
I changed the alternator and it cured everything. Too much voltage was being produced. I had a power steering leak which covered the alternator in muck & goo and probably led to it's demise.
Welcome to the forum, it is a good place with nice people...but then, we all love our Isuzu's, don't we?
FIRST HINT OF TROUBLE:
drove home one night and my lights started to go bright and dim as I drove and reved the engine but the next night and there after they ran steady...until it rained, and all my dash lights come on, then the engine stalled and I blew out the Fuel Pump relay.
Charged, dried drove and next rain, all the dash lights came on and it just eventually died
REMEDIES
To check for a short, I have disconected the NEG and attached a test light which did not light so I assume there is no short. I hosed the car from hood, tested again, still no sign of short.
Attached the NEG and a voltmete: Battery still at 12.67
Started the engine. Still 12.67 Reved the engine, no change
Turned on lights, 12.14
Turned of engine, back to roughly 12.6~
Also, when I reved the engineI noticed a "clanking sound' coming from the ALTERNATOR area but couldn't be possitive.
QUESTION:
Does it sound like a bad alternator to you?
Thanks for your help
Let us know what you find and keep us posted! Good luck and WELCOME to the forum! Lot of nice people here that like to help.
Did you figure out that all the goop from the leak caused the demise of your alternator? Did you replace the alt and p/s hose? Any info or advice you have would be greatly appriciated!
Glad to find fellow Trooper fans! I have a 95 Trooper LS with 210K miles on it. Driving today the "check transmission" warning light started blinking while we were driving at a slow speed. After I stopped and read the owners manual, sure enough I had to start in L and manually shift to get home (thankfully only a few miles). Apparently the computer when sensing a problem automatically bumps you into the manual mode. I checked the level and color of the transmission fluid and it was dirty and seemed low which leads me to believe it just needs a flush (I have had the car for almost 10 years and don't recall ever doing this). This is our first "problem" with the car since we have owned it and I am hoping it is only the transmission fluid. Any suggestions or other ideas? Thanks!
Rebuild alts are fine if OEM or Bosch. Still not cheap, but at least they work right with Isuzus. HTH one guys opinion.
Cheers Kayreen
replaced starter first
then battery & all cables....
worked for a white then it rained and my RELAY SWITCH blew.
I replaced it & the alternator and have had no problems since.
NOTE: My Trooper sat for days on end and still started up
NOTE: I have since given it to my nephew in college and back hills bike riding and it continues to start right up.
Best wishes
Kayreen
Thanx
Your year has two style of alt....one with IC regulator built in.....one outside. If your voltage regulator is outside, that is likely the cause.....otherwise, you seem to need to replace the alt. Make sure though, that the ring terminal on alt is not close to or grounding on alt case. Very commom problem when installing and tightening terminal nut. If it is OK, then above would apply.
Part nos. at www.myisuzuparts.com HTH One guys opinion
The only exception to this would be if you removed the battery and the alt was running the systems, in which case the regulator would spike all over the place as loads changed and it had no baseline 12 Volt signal from the battery. Never disconnect a battery from a running ECM controlled vehicle of any brand. It can have disastrous results.
HTH One guys opinion.
I'm experiencing pretty much what ostrander was with the voltage spiking to 16 but I also have the dash light all blinking on and off while it's spiking (I can here clicking as they do under the dash above my left knee) then it will return to normal but when I come to a stop the tranny starts like it's in third gear (very slow. it's an automatic) If I turn off the car and restart it, it drives normal for a while then will eventually Start all over again. Does this sound like the alt?? or Regulator??
Anyone else Having this problem besides me and ostrander.
Vince
Vince
By the way it is a 97 3.2L Sorry about that.
Thanks for your quick response and help atfdmike.
Vince
1995 Trooper LS 3.2 has what feels to be some sort of miss/hesitation and when and if I pull my 4 wheeler the transmission seems to go into creep mode after a while not want to shift and transmission light goes crazy. Also my dash/dummie lights are on (brake) and sometimes others. Alternator? Seems to test ok.
Nevermind....seems just like the same thing that Trooper97 was dealing with. I am just gonna replace the alternator!
@ynotnvme, good luck please let us know how it goes!
Alternator says ok during bench check but in vehicle says low. Can’t get warranty to replace it while they check int outside of car
